Topic: Impulse Response from Classical Music Record ? (Read 338 times) previous topic - next topic
MustafaUmutSarac
Youtube have many recordings of Guarneri Quartet. They have Cello Viola and Violin. Sometimes they play a chord together. If I record from that sequane  an 1 second cut , would that record works as impulse response ? And would it be musical ?
Umut
Istanbul
Grumpy_Mike
Quote
No, but it would act as an impulse.
An impulse response is something's response to receiving an impulse. For example in acoustics a room would have an impulse response, which is a measure of the amount of reverberation in a room. In a filter an impulse response will measure the amount of ringing in the filter.
A 1 second recording of something while it can be taken as an impulse, is a very poor one. Normally a rectangular stimulation is used because that contains an infinite number of harmonics and so tests all frequencies at the same time.
Quote
It depends on how you define musical. It will certainly be more tuneful than some of the music I listen to. But then I do listen to some weird stuff.
