Topic: Circuit Playground soft moon light (Read 363 times) previous topic - next topic
wizz
Hi all. I was thinking of to use my Circuit Playground as a moon light in my Vivarium and rely did not find any good code to start with or even a nice tutorial.
What i want is that when the light sensor see the daylight i got in the Vivarium turns of than the Circuit Playground start with a soft moon light and during time at night to be more bright and agian get back to an more soft light before the day ligth turns on again.
If any one got a solution pleas share that with me.
patduino
You might use an LDR to determine when "sundown" starts and a simple pot to adjust how long your night will be.  You would simply divide the "night" into 3 phases: ramp up the moonlight brightness to max, max moonlight, then slowly ramp it down to off.  I'd suggest using PWM to adjust the light levels.
PS - what animal?
There are 10 types of people in the world, those who understand binary, and those that don't.
wizz
There will be no animal at all just tropical plants.
Do you got an code example for that?
wizz
I used this code before on a light stripe for my aquarium and is it possible to use parts of it or the full code in to the circuit playground?
Here is the code.
Code: [Select]
const int STRAND_SIZE = 24; // we have a 30-LED strand
const byte STRAND_PIN = 6; // putting the neopixels on pin 6
Adafruit_NeoPixel strand = Adafruit_NeoPixel(STRAND_SIZE, STRAND_PIN, NEO_GRB + NEO_KHZ800);
//#define DEBUG
#ifdef DEBUG
const int MOON_WIDTH = 5; // make our moon 5 pixels wide.
const unsigned long NIGHT_TIMEms = 10L * 1000L; // 30 seconds
const unsigned long REDRAW_DELAYms =  100L; // redraw twice a second
const byte STRAND_BRIGHTNESS = 32; // one eightth brighness
#else
const unsigned long NIGHT_TIMEms = 10L * 60L * 60L * 1000L; // the night is 10 hours long - in milliseconds
const unsigned long REDRAW_DELAYms =  60L * 1000L; // redraw once a  minute - in milliseconds
const byte STRAND_BRIGHTNESS = 64; // one quarter brighness
#endif
unsigned long lastUpdate;
  strand.begin();
  // set the overall brightness of the strip to 160 out of a possible 255
  strand.setBrightness(STRAND_BRIGHTNESS);
  updateMoon();
  lastUpdate = millis();
#ifdef DEBUG
  Serial.begin(57600);
#endif
  // update every 60 minutes (meansured in milliseconds)
  if (millis() - lastUpdate > REDRAW_DELAYms) {
    updateMoon();
// ok. This function does the job of drawing the moon, based on what time it is.
void updateMoon() {
  strand.clear();
  float now = ((float)millis()) / ((float)NIGHT_TIMEms); // "now" is a number between 0 and 1
  if (now >= 1) return;
#ifdef DEBUG
  Serial.print(now);
  Serial.print('\t');
#endif
  // the overall brighness of the moon depends on the time.
  float moonBright = sin(now * PI);
  if (moonBright <= 0 ) return;
#ifdef DEBUG
  Serial.print(moonBright);
  Serial.print('\t');
#endif
  float moonPos = now * STRAND_SIZE;
  for (int i = -MOON_WIDTH / 2 - 1; i <= MOON_WIDTH / 2 + 1; i++) {
    int pix = moonPos + i;
    if (pix < 0 || pix >= STRAND_SIZE) continue;
    float bright = moonBright * cos((pix - moonPos) / MOON_WIDTH * PI);
    // 'bright' may be negative at the start and end of the edge of the moon
    if (bright > 0) {
      bright = bright * bright; // this changes the profile of the sin by a bit
      strand.setPixelColor(
        pix,
        // 200/200/255 should be a nice bluish white
        (int)(0xE0 * bright),
        (int)(0xFF * bright)
  strand.show();
#ifdef DEBUG
#endif
wizz
No one that got a solution?
Or can help me in the right direction?
patduino
So.... what do you have running?
1. You mentioned your LDR light sensor.  Have you gotten that to work yet?
2. Can you control your kit's lights?
wizz
I got this now on the CP board right now https://github.com/schnoggo/jack-o-candle
So i have basically not any good other start to begin with to make what i want and as it is all new to me i seek help from any one how are willing to help me.
wvmarle
You probably should move this to the Project Guidance section, this board is for paid help.
Also do go and read the "How to use this forum" sticky, so you know what we need for informed help.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
PaulMurrayCbr
The problem, of course, is that the light itself influences light in the vivarium. But that's ok! You can build a thing whose job it is to keep the brigthness at a target level.
Of course, the correct values for the target LDR reading is a matter of experimentation.
If the LDR value gets *lower* as the light gets *brighter*, you'll need to reverse some of this logic:
Code: [Select]
const int TARGET_LDR_LEVEL = 40; // whatever
const int SLOP_FACTOR = 2;
byte current_LED = 0;
loop() {
  delay(1000); // this can be pretty slow
  current_LDR = read_the_LDR();
  if(current_LDR < TARGET_LDR-SLOP_FACTOR) {
    // need to turn the light BRIGHTER
    if(current_LED < 255) {
      current_LED ++;
      analogOut(LED_PIN, current_LED);
  else if(current_LDR > TARGET_LDR+SLOP_FACTOR) {
    // need to turn the light DIMMER
    if(current_LED >0) {
      current_LED --;
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
