Topic: Arduino stop to work with VB interface  (Read 152 times) previous topic - next topic
Nelceran10
Hello Everybody
Hello Everybody
I'm new in Arduino and I have a problem when I try to communicate VB.net 2017 and Arduino Mega. It's work fine once, but after it read it stop to work. Some times I need to close the program many time, to work again.
This is the code in Arduino
Code: [Select]
int jqz[]={8,9,10,11,12,13};
int ent[]={2,3,4,5,6,7};
int cont=6;
for(int conta=0;conta<cont;conta++)
  {pinMode(jqz[conta],OUTPUT);}
  {pinMode(ent[conta],INPUT_PULLUP);}
String jacu = Serial.readStringUntil('\n');
   if (jacu.equals("081")){          // Codigo de activacion de Jacuzzi
     digitalWrite(jqz[0],HIGH);
   else if (jacu.equals("080")){
     digitalWrite(jqz[0],LOW);
   if (digitalRead(pts[0])){            // Codigo del pin aseo 1
     digitalWrite(pts[0],true);
     Serial.write("pin0421");}
   else{
     digitalWrite(pts[0],false);
     Serial.write("pin0420");
When I compile it works fine and the serial monitor shows all information fine.
This is the code in VB
Code: [Select]
Imports ctrlHabitacion
Imports System.Windows.Forms
Imports System.IO.Ports
Imports System.IO
Imports System.Text
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Timer1.Start()
        Inicializa(hab1, 1)
        arduino.PortName = "COM8"
        arduino.BaudRate = 9600
        arduino.DataBits = 8
        arduino.Parity = IO.Ports.Parity.None
        arduino.StopBits = IO.Ports.StopBits.One
        If Not arduino.IsOpen Then
            arduino.Open()
        End If
    End Sub
Private Sub arduino_DataReceived(sender As Object, e As SerialDataReceivedEventArgs) Handles arduino.DataReceived
        Dim string1 As String = arduino.ReadExisting()
        If string1.Equals("pin020") Then
            hab1.bgcolor = Color.Blue
        End If
        Invoke(subrotinaSTR, string1)
    End Sub
    Sub tratamentoSTR(ByVal meustring As String)
        TextBox2.Text = meustring
    End Sub
It works only once and stops the communication and the Arduino turn off all lights.
Thanks for all help
Paul_KD7HB
A common problem is the Arduino is reset when the VB program opens the serial connection. The VB program must wait for that reset to complete before continuing. You do not wait for a few seconds after opening the VB serial connection.
Paul
Robin2
I get my Arduino program to print a message from setup() - for example Serial.println("Arduino is ready"); - and my PC program waits until it receives that before trying to talk to the Arduino.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
