Topic: The project is done (Old 49 keys casio) to midi using Arduino MEGA (Read 2996 times) previous topic - next topic
Oday_Alasali
OMG dude I guess that I found out this riddle and I'm solving it, will reply when done.
Oday_Alasali
I'm done dude at last  ;D I've spent a whole 9 hours to find this out and now I'm finally done 100%
just I want a favor from you to check if this code is good in the long term because I don't know how to check that.
and the last thing but its doesnt matter if its unsolvable (there is a little noise when a tone is played but its not affecting the sound) but will be awesome if its solved .
Code: [Select]
#include <MIDI.h>
#include <Keypad.h>
const byte ROWS = 6; //six rows
const byte COLS = 9; //nine columns
char keys[COLS][ROWS] = {
  {48, 54, 60, 66, 72, 78},
  {84, 90, 96, 49, 55, 61},
  {67, 73, 79, 85, 91, 96},
  {50, 56, 62, 68, 74, 80},
  {86, 92, 97, 51, 57, 63},
  {69, 75, 81, 87, 93, 98},
  {52, 58, 64, 70, 76, 82},
  {88, 94, 99, 53, 59, 65},
  {71, 77, 83, 89, 95, 101}
byte rowPins[ROWS] = {26, 28, 30, 32, 34, 36,}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {A0, A1, A2, A3, A4, A5, A6, A7, A8}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
byte keyToMIDI[] = { 48,49,50,51,52,53,54,55,56,57,58,59,60,61,62,63,64,65,
                     66,67,68,69,70,71,72,73,74,75,76,77,78,79,80,81,82,83,
                     84,85,86,87,88,89,90,91,92,93,94,95,96,97,98,99,100,101,
                     102,103,104,105,106,107,108};
byte pressed = 32;
byte chanel = 0; // MIDI channel to use
 Serial.begin(115200); // set this the same as Hairless
 // Fills kpd.key[49] array with up-to 10 active keys.
 // Returns true if there are ANY active keys.
 if (kpd.getKeys())
   for (int i = 0; i < LIST_MAX; i++) // Scan the whole key list.
     if ( kpd.key[i].stateChanged )   // Only find keys that have changed state.
       pressed = keyToMIDI[kpd.key[i].kchar - 36];
       switch (kpd.key[i].kstate) {  // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
         case PRESSED:
           sendMIDI(chanel | 0x90, pressed, 100);
          case RELEASED:
           sendMIDI(chanel | 0x80, pressed, 64);
}  // End loop
void sendMIDI(byte type, byte note, byte velocity){
  Serial.write(type);
  Serial.write(note & 0x7F);
  Serial.write(velocity);
Grumpy_Mike
Well first off many congratulations on what you have achieved so far. You can remove that KeyToMIDI array as it dosn't do much, it is just a fancy way of adding an offset. This is your code with it removed:-
Code: [Select]
#include <MIDI.h>
#include <Keypad.h>
byte pressed = 32;
 if (kpd.getKeys())
       pressed = kpd.key[i].kchar + 12;
         case PRESSED:
          case RELEASED:
}  // End loop
  Serial.write(type);
However, I am not seeing any MIDI note off messages on my lash up of what you have. You will not notice the lack of note off messages if your sounds are percussive, like a bell, or glockenspiel and so on. But if you have a sound in the Synth Pad range sounds 89 to 96 and many others the note will hang, that means it will not stop and keep playing even when the key is released.
Can you please:-
1) Test this code and see if it does what your original one does.
2) Check that you are getting the MIDI note off messages on your system by trying other sounds or running some sort of MIDI monitor to see what hairless is putting out.
Thanks
Oday_Alasali
I've tried this code and gone along with all sounds piano \ synths ....everything and its doing the job perfectly with ons and offs.
but as I said there is a little background noise happening when a note is playing, even thou its not harmful but would be great to find out why. And many thanks for handling me for this whole while because you were giving me clues.
Grumpy_Mike
Quote
Unless you can see something on a MIDI monitor connected after hairless then I don't think it has anything to do with the keyboard. It is possibly something to do with the MIDI sound generator or your speaker system.
Oday_Alasali
Well I don't know what was happening but I was using the arduino through the front usb port I moved it to the rear port and that solved it.
Now I'm totally done with this and I hope that this whole post would help someone in the future
Many Thanks.
thoyibbasarah
#66
Sep 10, 2020, 02:56 pm Last Edit: Sep 10, 2020, 03:15 pm by thoyibbasarah Reason: More complete..
Thumb up for Grumpy_Mike for supporting well... Is this thread still opened to discuss?
My case key matrix 8x8 but 61keys with diode. MCU STM32 blue pill with arduino IDE. Library keypad.h and usb composite. Why i have to use 10k res to prevent repeating note. Case 2 although every key have diode but i still got ghosting key when pressing two notes in different column. But everything running well when pressing single note and 3 or 4 notes from 3rd octave to higher octave. I've checked the line of PCB and nothing is short connection. Its really made me a headache.
Sorry my bad english...
Grumpy_Mike
Quote
Where do you have to use a 10K? As this is a different circuit we are working on ween need to see how you have wired it up to what pins. So can you post a schematic please, showing all the connections.
Quote
That could be something to do with wiring or something to do with software so we need to see your code as well.
