Topic: Transfer Credentials from Web Form to WiFiNINA (Read 29 times) previous topic - next topic
alioshaw
Hi There
I try to get the credentials I input on a website (served by my MKR1010 in AP mode) passed trough to WiFi.begin of the WiFiNINA Library. Somehow it doesn't work. If I hardcode the credentials everything works fine...
I have a String that I get from the http request, which is OK (tested via print()) and I convert it here:
char *strToChar(String str) {
  int len = str.length() + 1;
  char c[len];
  str.toCharArray(c, len);
  return c;
to use it here:
WiFi.begin(strToChar(network), strToChar(password));
any ideas or someone who did this before?
Deva_Rishi
I do do this, but not using a function, but just as a local declaration.
Code: [Select]
void TryConnect(String ssid, String password) {  // try to connect to this network
  char namebuf[ssid.length()+1];
  ssid.toCharArray(namebuf,ssid.length()+1);
  char passbuf[password.length()+1];
  password.toCharArray(passbuf,password.length()+1);
  WiFi.begin(namebuf, passbuf);
this does work for me.
To 'Correct' you have to be Correct. (and not be condescending..)
