Hi!
I need to do stqc decoder on Arduino Mega2650.
I've tried this code:
#define SOUND_PIN 47
int Htime, Ltime, prescale = 1;
float Ttime, frequency;
pinMode(SOUND_PIN, INPUT);
Serial.println("Frequency: ");
Htime=pulseIn(8,HIGH);
Ltime=pulseIn(8,LOW);
Ttime = Htime+Ltime;
frequency=1000000/Ttime;
frequency=frequency*prescale;
Serial.print(frequency);
Serial.println(" Hz");
This code gived me frequency ifinity.
I've tried to use FreqCount and FreqMeasure, but they wasn't working as I expected.
Here is code, which reacts playing audio, but shows to small frequency:
Serial.println("Frequency :");
long number=0, time1=micros();
do
if (digitalRead(SOUND_PIN)==HIGH) {
while (digitalRead(SOUND_PIN)==HIGH) {}
number++;
}while (micros()<(time1+1000000));
Serial.print(number);
I'm using LCD Keypad Shield so some pins are unavailable.
If some thing is wrong in code, I want to understand this correct one.
For exemple, I don't understand this code (this one isn't working too):
// input on pin D47 (T5)
volatile unsigned long timerCounts;
volatile boolean counterReady;
unsigned long overflowCount;
unsigned int timerTicks;
unsigned int timerPeriod;
void startCounting (unsigned int ms)
counterReady = false; // time not up yet
timerPeriod = ms; // how many 1 ms counts to do
timerTicks = 0; // reset interrupt counter
overflowCount = 0; // no overflows yet
// reset Timer 2 and Timer 5
TCCR2A = 0;
TCCR2B = 0;
TCCR5A = 0;
TCCR5B = 0;
// Timer 5 - counts events on pin D47
TIMSK5 = bit (TOIE1); // interrupt on Timer 5 overflow
// Timer 2 - gives us our 1 ms counting interval
// 16 MHz clock (62.5 ns per tick) - prescaled by 128
// counter increments every 8 µs.
// So we count 125 of them, giving exactly 1000 µs (1 ms)
TCCR2A = bit (WGM21) ; // CTC mode
OCR2A = 124; // count up to 125 (zero relative!!!!)
// Timer 2 - interrupt on match (ie. every 1 ms)
TIMSK2 = bit (OCIE2A); // enable Timer2 Interrupt
TCNT2 = 0;
TCNT5 = 0; // Both counters to zero
// Reset prescalers
GTCCR = bit (PSRASY); // reset prescaler now
// start Timer 2
TCCR2B = bit (CS20) | bit (CS22) ; // prescaler of 128
// start Timer 5
// External clock source on T4 pin (D47). Clock on rising edge.
TCCR5B = bit (CS50) | bit (CS51) | bit (CS52);
} // end of startCounting
ISR (TIMER5_OVF_vect)
++overflowCount; // count number of Counter1 overflows
} // end of TIMER5_OVF_vect
// Timer2 Interrupt Service is invoked by hardware Timer 2 every 1 ms = 1000 Hz
// 16Mhz / 128 / 125 = 1000 Hz
ISR (TIMER2_COMPA_vect)
// grab counter value before it changes any more
unsigned int timer5CounterValue;
timer5CounterValue = TCNT5; // see datasheet, (accessing 16-bit registers)
// see if we have reached timing period
if (++timerTicks < timerPeriod)
return; // not yet
// if just missed an overflow
if (TIFR5 & TOV5)
overflowCount++;
// end of gate time, measurement ready
TCCR5A = 0; // stop timer 5
TCCR5B = 0;
TCCR2A = 0; // stop timer 2
TCCR2B = 0;
TIMSK2 = 0; // disable Timer2 Interrupt
TIMSK5 = 0; // disable Timer5 Interrupt
// calculate total count
timerCounts = (overflowCount << 16) + timer5CounterValue; // each overflow is 65536 more
counterReady = true; // set global flag for end count period
} // end of TIMER2_COMPA_vect
void setup ()
Serial.println("Frequency Counter");
void loop ()
// stop Timer 0 interrupts from throwing the count out
byte oldTCCR0A = TCCR0A;
byte oldTCCR0B = TCCR0B;
TCCR0A = 0; // stop timer 0
TCCR0B = 0;
startCounting (500); // how many ms to count for
while (!counterReady)
{ } // loop until count over
// adjust counts by counting interval to give frequency in Hz
float frq = (timerCounts * 1000.0) / timerPeriod;
// restart timer 0
TCCR0A = oldTCCR0A;
TCCR0B = oldTCCR0B;
Serial.print ("Frequency: ");
Serial.println ((unsigned long) frq);
// let serial stuff finish
delay(200);
In this one, I don't understand these: TCCR0A, TCCR0B and so on.
I think, the problem is in circuit too.
In attachments circuit image.
Sorry for mistakes.
Thanks in advance for any help.
