Topic: Trouble using Serial.read() (Read 182 times) previous topic - next topic
Railroader
Using Serial monitor I send commands to the UNO.
If I send the string "X123Cr" it works well but if I send "XCr" and then "123Cr" only "1" is received.
 What am I missing?
The code is too large to attach using code tags. I try to attach the central piece.
Start looking at functiion Figures and case "S". If I then send the string X123 Cr it works, I get the numeric of 123, but when I send X Cr and then 123 Cr I only get the number 1 when calling get_num().
What am I missing?
Code: [Select]
long get_num()
  long get_num_sum = 0;
  int sign = 1;
  char got_char;
  while (!Serial.available() );
  got_char = Serial.read();
  //  Serial.print("Got char 1 "); Serial.println(got_char);
  if (got_char == '-' )
    sign = -1;
    get_num_sum = 0;
    //    Serial.print("Sum inside sign check - "); Serial.println(get_num_sum);
    get_num_sum = long(got_char - '0');
  while (Serial.available())
    Serial.print("Got char n "); Serial.println(got_char); Serial.print("sum = "); Serial.println(get_num_sum);
    //    if (isAlphaNumeric(got_char)) sum = (sum * 10) + long(got_char - '0');
    get_num_sum = (get_num_sum * 10) + long(got_char - '0');
  Serial.print("Get_num reads "); Serial.println(get_num_sum * sign);
  return (get_num_sum * sign);
char get_cmd()
  return (Serial.read());
void figures()
  char cmd, cmd_2;
  long depth = 81;
  int motor = motorX;
  int nr_steps;
  long step_delay2;
  mylcd.clear();
  mylcd.print("C Circle");
  mylcd.setCursor(0, 1);
  mylcd.print("H Hole");
  mylcd.setCursor(0, 2);
  mylcd.print("S Step motor");
  mylcd.setCursor(0, 3);
  mylcd.print("Z Set axle to zero");
  //             01234567890123456789
  cmd = get_cmd();
  switch (cmd)
    case 'C': Serial.print("Figure circle ended "); Serial.println(millis());
    case 'c':
        mylcd.clear();
        mylcd.print("Circl Depth Rad  Ang");
        global_angle_print_flag = true;
        global_depth_print_flag = true;
        //void makecircle(float (angle_start), float (angle_stop), long(xcenter), long(ycenter), long(radius), float(astep))
        digitalWrite( 8, LOW);//Enable motorpower
        Serial.print("Figure circle started "); Serial.println(millis());
        for (int i = 40; i < depth; i += 40)
          goxyz(motorZ, zpos - 40, zwork_delay);
          mylcd.setCursor(8, 1); mylcd.print("    "); mylcd.setCursor(8, 1); mylcd.print(zpos);
          makecircle(0, 2 * pi, 4000, 4000, 800, 10.0 / 360.0 * pi); //2 degrees stepping angle
        global_angle_print_flag = false;
        global_depth_print_flag = false;
        goxyz(motorZ, 0, ztransport_delay);
        goxyz(motorX, 0, xtransport_delay);
        goxyz(motorY, 0, ytransport_delay);
        digitalWrite( 8, HIGH);//Disable motorpower
    case 'H':
    case 'h':
        mylcd.clear();
        mylcd.print("H Hole De   Rad  Ang");
        global_radious_print_flag = true;
        // makehole(float (angle_start), float (angle_stop), long(xcenter), long(ycenter), long(radius), float(astep))
        Serial.print("Figure hole started "); Serial.println(millis());
          makehole(0.0, 2 * pi, 4000, 4000, 1200, 10.0 * pi / 360.0); //1 degree stepping angle
        global_radious_print_flag = false;
        Serial.print("Figure hole ended "); Serial.println(millis());
    case 'S'://Step motor
    case 's':
        mylcd.clear();
        mylcd.print("Step motor ");
        mylcd.setCursor(0, 1); mylcd.print("Motor. X, Y, Z ");
//        global_radious_print_flag = true;
        Serial.print("Stepping motor ");
        cmd_2 = get_cmd();
        switch (cmd_2)
          case 'X':
          case 'x':
              motor = motorX;
              step_delay2 = xtransport_delay;
              mylcd.print("X");
              Serial.println("X");
              nr_steps = get_num();
              mylcd.setCursor(0, 2); mylcd.print("Steps "); mylcd.print(nr_steps);
              goxyz(motorX, xpos + nr_steps, xtransport_delay);
          case 'Y':
          case 'y':
              motor = motorY;
              step_delay2 = ytransport_delay;
              mylcd.print("Y");
              Serial.println("Y");
              goxyz(motorY, ypos + nr_steps, ytransport_delay);
            }        //                          01234567890123456789
          case 'Z':
          case 'z':
              motor = motorZ;
              step_delay2 = ztransport_delay;
              mylcd.print("Z");
              Serial.println("Z");
              goxyz(motorZ, zpos + nr_steps, ztransport_delay);
        }//End of case step motor
        mylcd.clear();
        pos_print(xpos, ypos, xpos);
        mylcd.setCursor(0, 0); mylcd.print("Send a char to skip");
        cmd = get_cmd();//In order yo leave set zero
        //        break;
      }//End of switch step motor
    case 'Z'://Set axle to zero
    case 'z':
        mylcd.clear();
        cmd_2 = get_cmd();
        switch (cmd_2)
          case 'X':
          case 'x':
              xpos = 0;
          case 'Y':
          case 'y':
              ypos = 0;
          case 'Z':
          case 'z':
              zpos = 0;
        }//End switch cmd set zero
        mylcd.clear();
      }//End of Zero axle stepping
      mylcd.clear();
  }//end of switch cmd
}//End of figures
Use Your knowledge. If that's not enough, look for education.
Having knowledge, think outside the box to gain more of it. Only trains run like the train, on the rails. The rest run between the rails.
PaulS
Code: [Select]
  char got_char;
The value of got_char - '0' will be in the range 0 to 9. Why are you forcing that to be a long?
Code: [Select]
Missing a break statement.
Create a minimal test sketch that illustrates the problem, or post ALL of your code. There is no reason to include a sh*tload of code to use the data that you can't receive and parse data correctly.
Railroader
Thanks PaulS
How do I do to attach an .INO file at this moment? The sketch is too large to be put into Code tags.
The case 'C' and Serial.print was an accidental Ctrl V at some time and it is corrected now. It doesn't change anything
Making a stepper motor of 400 steps per millimeter move some 200 mm needs 400*200 == 80 000 steps. A little too much for Integers....
The two ways of sending the string are X123 Carriage Return, or X Carriage Return, 123 Carriage return. The first way works, the second onle gives the value 1.
Isn't The Cr dropped in Serial.read, treated as a delimiter?
I'll try to create a test sketch later today. Cutting away code without loosing neccessary lines is never an easy task
Railroader
@PaulS
I just got the sketch working. Some break were missing here and there. Improved the debug info sent in Serial.print.
Thanks for Your support!
