Topic: [SOLVED] Activating a Button outside of Arduino (Read 3655 times) previous topic - next topic
Vini
May 19, 2011, 12:35 am Last Edit: May 23, 2011, 10:00 pm by Vini Reason: 1
Hey guys, how are you? Hope fine.
I'm trying to activate a button of a mp3 player with Arduino. Well, the main idea is very simple, just make a short with 2 wires in a tiny period of time to "simulate" a button pressed (the mp3 player has a smd pushbutton where I soldered 2 wires to make the short). Anyone have a idea how can I do that? I know I can use a relay, but I don't want to make a large final solution so, I was thinking in something smaller.
Well, thanks for your help anyway.
Bye (:
rbtying
A transistor would work, and they can be very small.  Also, if you can figure out what the voltage going through the switch is, it may be possible to hook it up to a digital output and just use digitalWrite.
zoomkat
I've used transistors to simulate button pushes on a tv remote and it worked well. An optical isolator chip might also be a good option (but the local radio shack does not carry them).
Vini
Hey,
The idea with transistor is what this picture shows?
Vini
Can you post a circuit please?
Thank you :)
zoomkat
Grumpy_Mike
It would do if it were right, but its wired up all wrong.
While a transistor can work, much better is an FET as this actually changes resistance. I have had situations where a transistor would not trigger something but an FET would. Remember you also need to connect the ground of your device and the arduino ground together.
Vini
Grumpy_Mike, what is the right way to wire this?
Thanks for your help!
And thanks zoomkat for the website!
Vini
My old image is wrong, I mean this:
What is the right way to hook that wires?
Grumpy_Mike
That is right, I was referring to the first image you posted.
Vini
Hey Grumpy_Mike,
I'm sorry for inconvenience but, can you send to me the circuit that works with FET? I'm having a lot of trouble with this circuit.
Thank you very much.
Grumpy_Mike
Just replace the transistor with a logic level FET and make the base resistor (which is now a gate resistor) 100R.
Do not connect the drain (was the collector) to +12V or a resistor but common up the grounds between your device and the arduino.
biocow
I tried a transistor and it wasn't working, but only cause n00b me forgot to connect the grounds together. So I went with a relay instead.
http://arduino.cc/forum/index.php/topic,49979.0.html
Vini
I'll try with the FET tomorrow. I used a 12V relay and it worked but when the pushbutton was pressed by the relay, I heard a loud noise on the speaker - don't know why..
Vini
Problem Solved!
Here is the final circuit working!
Thanks for everybody!
