Here's my final code :
Also, I didn't know how to include the controlChange void in the loop...
#include "MIDIUSB.h"
#include "PitchToNote.h"
const byte _NLED = 100;
const byte _DPIN = 6;
Adafruit_NeoPixel _LED = Adafruit_NeoPixel(_NLED, _DPIN, NEO_GRB + NEO_KHZ800);
const byte _R[128] = {0, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 45, 93, 142, 223, 190, 28, 61, 93, 190, 125, 12, 28, 45, 158, 61, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 12, 28, 45, 158, 61, 28, 61, 93, 190, 125, 45, 93, 142, 223, 190, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 36, 73, 109, 146, 182, 219, 255};
const byte _G[128] = {0, 0, 0, 0, 125, 0, 12, 28, 45, 158, 61, 28, 61, 93, 190, 125, 45, 93, 142, 223, 190, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 45, 93, 142, 223, 190, 28, 61, 93, 190, 125, 12, 28, 45, 158, 61, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 36, 73, 109, 146, 182, 219, 255};
const byte _B[128] = {0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 0, 0, 0, 125, 0, 12, 28, 45, 158, 61, 28, 61, 93, 190, 125, 45, 93, 142, 223, 190, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 61, 125, 190, 255, 255, 45, 93, 142, 223, 190, 28, 61, 93, 190, 125, 12, 28, 45, 158, 61, 36, 73, 109, 146, 182, 219, 255};
const byte _PStart = 36; // First note in array
bool update = false;
_LED.begin();
_LED.show();
midiEventPacket_t rx;
do {
rx = MidiUSB.read();
if(rx.header == 0x9) noteOn(rx.byte1, rx.byte2,rx.byte3);
if(rx.header == 0x8) noteOff(rx.byte1, rx.byte2,rx.byte3);
while (rx.header == 0); // hold until a MIDI message is received
if (update) {
_LED.show();
update = false;
void noteOn(byte channel, byte pitch, byte velocity) {
_LED.setPixelColor(pitch - _PStart, _R[velocity], _G[velocity], _B[velocity]);
update = true;
void noteOff(byte channel, byte pitch, byte velocity) {
_LED.setPixelColor(pitch - _PStart, 0, 0, 0);
update = true;
void controlChange(byte *data, unsigned int length) {
if (length == 6) {
_LED.setPixelColor(*(data+1) - _PStart, *(data+2), *(data+3), *(data+4));
update = true;
Sometimes, when there are a lot of notes pressed at the same time, the leds take a much more long time to do the light effect than it is supposed to (the light effects contains +-600 notes to play in two seconds or so)... And I use Ableton live
