Topic: nrf24.send PROBLEM (Read 132 times) previous topic - next topic
sbabakp
I write a code and I use NRF24l01 then I need to send info from transmitter to receiver to turn the LED's ON,I'm okay with but there is a problem,transmitter don't send 0 and you its between 0-255 it send the array from 1 - 255
I wanna send 0-255
how can I fix it
its my command for send
        uint8_t Array[4];
        nrf24.send((uint8_t *)&Array, sizeof(Array));
UKHeliBob
Post your complete program
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
sbabakp
UKHeliBob
A picture of you code is useless
Please read this before posting a programming question and follow its advice on how to post or attach code here
sbabakp
Code: [Select]
    if (ledPin == 11)
     if  (val != old_val3)
          Array[2]=map(val, 0, 100, 0, 255);
        nrf24.send((uint8_t*)&Array, sizeof(Array));
      nrf24.waitPacketSent();
      Serial.print("send data TIMER ch3 : ");
      Serial.println(Array[2]);
          old_val3= val;
          final_val3=val;
UKHeliBob
sbabakp
Try a simple example like this first
Simple nRF24L01+ 2.4GHz transceiver demo
I did,
and I have no problem with that
but because of some reasons I had to use radiohead library until then I have this problem that I cant send 0 with the bellow code for send
Code: [Select]
UKHeliBob
Your code
Code: [Select]
Robin's code that you say works
Code: [Select]
   rslt = radio.write( &dataToSend, sizeof(dataToSend) );
Why the difference ?
What happens if you send a byte with a value of zero rather than an array ?
Robin2
I did,
Why not use the TMRh20 RF24 library if you have proved to yourself that it works?
I have no experience with the Radiohead library.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
