Topic: TP4056 Ground isolation (Read 75 times) previous topic - next topic
sp33dsk8
May 16, 2019, 07:41 am Last Edit: May 16, 2019, 08:14 am by sp33dsk8
Greetings, I'm building a solar project to monitor charge current and discharge current as well as lipo 'State Of Charge'.
The configuration is a 5V solar panel feeding a TP4056 which B+/- connect to a MAX471 bidirectional current monitor which connects to a LiPo in parallel with a MAX17043G lipo fuel gauge.
Unfortunately in this configuration with sensors on the B+/- outputs I cannot associate my TP OUT ground pin to those sensors without creating a ground loop that would prevent TP protection from working properly.  I understand this is a non-typical configuration but this is the only way I could monitor charge & discharge current with one sensor and one analog pin.
Any input would be greatly appreciated.
Datasheets:
CHRG - https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf
Current Sense - https://pdfserv.maximintegrated.com/en/ds/MAX471-MAX472.pdf
Fuel Gauge - https://datasheets.maximintegrated.com/en/ds/MAX17043-MAX17044.pdf
Ugly schematic attached
