Topic: How to divide a number in two bytes (Read 415 times) previous topic - next topic
ciao4735
We are trying to save a number > 255 in a EEPROM cell. Please we need an example code.
srnet
Examples here;
EEPROM Library
That reference page turns up when you do a Google search on 'Arduino EEPROM reference'
http://www.50dollarsat.info/
http://www.loratracker.uk/
GolamMostafa
#2
May 31, 2019, 05:00 am Last Edit: May 31, 2019, 05:01 am by GolamMostafa
Code: [Select]
int x = 321; //0x0141
EEPROM.write(0x0010, highByte(x));      //0x01 is written at location 0x0010 of internal EEPROM
EEPROM.write(0x0011, lowByte(x));      //0x41 is written at location 0x0011 of internal EEPROM
sterretje
Use EEPROM.put() and EEPROM.get(); it will write and read any variable type as needed (with exception if String (capital S)).
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
GolamMostafa
The OP is asking for the division of a number into two bytes before the number is stored into EEPOM. The EEPROM.put() command, of course, divides the number into two bytes before writing it into EEPROM; but, the process happens beyond the knowledge of the user.
sterretje
Based on the title, you are right. Based on the text (store a number greater than 255), my solution is also a possibility ;)
Although OP asks "in a cell" which is not posible; it will be two or more cells.
