Topic: Multiple input - outputs (Read 412 times) previous topic - next topic
Paul__B
Now that is looking neat.
My recommendation is to use the module I linked in reply #1.
(I ordered one when I looked it up.  :smiley-lol: )
Robi26
#16
May 24, 2019, 01:27 pm Last Edit: May 24, 2019, 01:29 pm by Robi26
I would be the best to use module.
A few more things. If you look at datasheet, at page 3.
http://www.ti.com/lit/ds/symlink/pcf8575.pdf
Pins A0, A1 and A2 are for determinate I2C adress. It says you can connect them to Vcc or GND (picture on page 1 and 23 showing connection to GND).
Description of pins P00 to P16 is input/output - push/pull design structure.
What is meaning of push/pull?
Pull up - for get signal you connect pin to gnd?
Push down - for get signal you connect pin to Vcc?
Is this two correct?
Grumpy_Mike
#17
May 24, 2019, 06:41 pm Last Edit: May 24, 2019, 06:42 pm by Grumpy_Mike
When talking about inputs you pull up or pull down.
When talking about outputs you don't so much say push, as say to source or sink current.
