Topic: decoding pair-wise inputs (Read 215 times) previous topic - next topic
rubinj
Hi all,
I'm looking for an idea to solve the following: given 4 input terminals - A, B, C and D (simple electrical wires), the controller needs to decode which of pairs are connected. For example: A-C, or B-D, etc...
Any ideas?
Thanks in advance,
Jonathan
PixelDeath
I haven't tested it but this should give you a good jumping off point. If it works as I intended the bools AB, AC, AD... should be contently set to what pins are connected.
Code: [Select]
void setup() {}
//defining pins, changes these to the pins you want to check
const int A = 1;
const int B = 2;
const int C = 3;
const int D = 4;
//defining connections
bool AB = false;
bool AC = false;
bool AD = false;
bool BC = false;
bool BD = false;
bool CD = false;
  pinMode(A,OUTPUT);//set one pin to output
  pinMode(B,INPUT);  //set the rest to input
  pinMode(C,INPUT);
  pinMode(D,INPUT);
  digitalWrite(A, HIGH);
  AB = digitalRead(B); //if the pin is high(true) it means it's connected to the only pin outputting
  AC = digitalRead(C);
  AD = digitalRead(D);
  pinMode(A,INPUT);
  pinMode(B,OUTPUT);
  pinMode(C,INPUT);
  pinMode(D,INPUT);
  digitalWrite(B, HIGH);
  BC = digitalRead(C); //we don't need to check as many because they have already been looked at, eg A connected to B is the same ans B connected to A
  BD = digitalRead(D);
  pinMode(A,INPUT);
  pinMode(B,INPUT);
  pinMode(C,OUTPUT);
  pinMode(D,INPUT);
  digitalWrite(C, HIGH);
  CD = digitalRead(C);
//D never needs to be an ouput because it is checked by the rest
PaulRB
#2
May 16, 2019, 08:26 pm Last Edit: May 16, 2019, 08:26 pm by PaulRB
Quote
With floating inputs? I doubt it.
larryd
const int A = 1;
Suggest you not use pin 1 as it is the serial TX pin.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
cattledog
#4
May 16, 2019, 09:58 pm Last Edit: May 16, 2019, 10:00 pm by cattledog
Quote
Change the INPUT to INPUT_PULLUP.
DigitalWrite() the OUTPUT pin LOW instead of HIGH.  An output pin written LOW is connected to ground and can sink current.
The digitalRead() if the INPUT_PULLUP pin will be LOW if it is connected to the pin which is output and low.
Code: [Select]
void setup() {}
const int A = 5; //1;
const int B = 2;
const int C = 3;
const int D = 4;
bool AB = false;
bool AC = false;
bool AD = false;
bool BC = false;
bool BD = false;
bool CD = false;
  pinMode(B,INPUT_PULLUP);  //set the rest to INPUT_PULLUP
  pinMode(C,INPUT_PULLUP);
  pinMode(D,INPUT_PULLUP);
  digitalWrite(A, LOW);
  AB = digitalRead(B); //if the pin is LOW(false) it means it's connected to the only pin outputting
  pinMode(A,INPUT_PULLUP);
  pinMode(B,OUTPUT);
  digitalWrite(B, LOW);
  pinMode(C,OUTPUT);
  digitalWrite(C, LOW);
  //CD = digitalRead(C);
  CD = digitalRead(D);
rubinj
rubinj
one thing:
when A-B is connected, I get 'AB'
when C-D is connected, I get 'CD'
but, when both A-B and C-D are connected,
I get: AB, AC, AD, BC and CD...
Grumpy_Mike
Quote
Yes you will. Why would you expect anything else?
rubinj
if A-B and C-D are connected, i'd like to get only: 'AB' and 'CD' (as the rest are not connected..)
PaulRB
#9
May 17, 2019, 05:37 pm Last Edit: May 17, 2019, 05:41 pm by PaulRB
Try (untested):
Code: [Select]
const byte pins[4] = {5, 2, 3, 4};
const char names[4] = {'A', 'B', 'C', 'D'};
  for (byte i=0; i<4; i++) pinMode(pins[i], INPUT_PULLUP);
  for (byte i=0; i<3; i++) {
    pinMode(pins[i], OUTPUT);
    digitalWrite(pins[i], LOW);
    for (byte j=i+1; j<4; j++) {
      if (digitalRead(pins[j]) == LOW) {
        Serial.print(names[i]);
        Serial.print("-");
        Serial.print(names[j]);
        Serial.print(" ");
rubinj
