Topic: Fresh Eyes Needed - Stuttering Motor Issues  (Read 259 times) previous topic - next topic
ZipZoomFly
May 17, 2019, 12:26 am Last Edit: May 17, 2019, 01:24 am by ZipZoomFly
Have a 48 VDC brushed motor, a Cytron MDS40B controller, Arduino Uno (r3), single axis rocker potentiometer.
Everything seems to be working fine, except the motor has an intermittent (and persistent) stutter at any potentiometer input - slow to fast - and either direction. I've replaced every bit of hardware in an effort to chase down the problem, but it persists, so I'm left to believe it's glitch in the code - the one thing I know essentially nothing about...
Desired operation is pretty simple: The speed and direction of a brushed DC motor is controlled by a single axis potentiometer (center-sprung thumbstick). The motor moves a device in 2 directions on a single axis. There are NC limit switches at either end of the axis. There is an adjustable (via code) speed ramp-down function to prevent instant stopping once a limit switch is hit. There is an emergency stop function. There is also a speed limit function: set a switch in one direction and full throttle only allows 50% power to the motor; set in the other direction full throttle sends 100% power to the motor.
That's it, essentially.
Original coder is unavailable. Any help, guidance or outright fixes will be greatly appreciated (and potentially compensated). Anyone see a glaring glitch (or outright error) in this code:
Code: [Select]
#include "CytronMotorDriver.h"
#define PWM 5
#define DIR 6
// Configure the motor driver.
CytronMD motor(PWM_DIR, PWM, DIR);  // PWM = Pin 3, DIR = Pin 4.
#define ramp_down_speed 10    //increasing the number will slow the ramp down process and vice versa
#define noise_window 10 //assuming at rest position potentiometer will output voltage VCC/2. When potentiometer is tilt forward it will output in the range VCC/2-VCC and vice versa.
//As per data sheet there is tolerance in accuracy of rest position. noise window will ensure that when potentiometer is at rest motor is also not moving.
const int Pot_Pin = A0;    // select the input pin for the potentiometer
const int FSW_Pin = 7;    // select the input pin for the forward limit switch
const int BSW_Pin = 8;    // select the input pin for the backward limit switch
const int ESW_Pin = 9;    // select the input pin for the emergency stop
const int SLS_Pin=10; //Speed limit switch pin
bool BSW_state = 0;
bool FSW_state = 0;
bool ESW_state = 0;
int power = 0;
int forward_power = 0;
int backward_power = 0;
int last_forward_power = 0;
int last_backward_power = 0;
int last_power = 0;
  pinMode(FSW_Pin, INPUT_PULLUP);
  pinMode(BSW_Pin, INPUT_PULLUP);
  pinMode(ESW_Pin, INPUT_PULLUP);
  pinMode(SLS_Pin, INPUT_PULLUP);
  ESW_state = digitalRead(ESW_Pin);
  if (ESW_state == LOW)
    BSW_state = digitalRead(BSW_Pin);
    FSW_state = digitalRead(FSW_Pin);
    power = get_direction();
    if (power < 0 && BSW_state == LOW)
      backward_power = power;
    else if (power > 0 && FSW_state == LOW)
      forward_power = power;
    if (FSW_state == HIGH)
      //Serial.println("                   Ramp forward");
      ramp_down_forward(forward_power);
      forward_power = 0;
    if (BSW_state == HIGH)
      //Serial.println("                   Ramp Backward");
      ramp_down_backward(backward_power);
      backward_power = 0;
    if (BSW_state == LOW && FSW_state == LOW)
      // Serial.print("Power value=");
      // Serial.println(power);
      motor.setSpeed(power);
      delay(50);
    else if (FSW_state == LOW)
      //  Serial.print("Forward Power value=");
      // Serial.println(forward_power);
      motor.setSpeed(forward_power);
      delay(50);
    else if (BSW_state == LOW)
      // Serial.print("Backward Power value=");
      // Serial.println(backward_power);
      motor.setSpeed(backward_power);
      delay(50);
    // Serial.println("Emergency Mode");
    motor.setSpeed(0);
int get_direction()
  int x = analogRead(Pot_Pin);
  if((x<511+noise_window)&&(x>511-noise_window))
    return 0;
  if(digitalRead(SLS_Pin)==HIGH)
    return map(x, 0, 1023, -128, 128);//full speed
  else if(digitalRead(SLS_Pin)==LOW)
    return map(x, 0, 1023, -64, 64);//half speed
void ramp_down_backward(int x)
  // Ramp down from current value motor to 0
  if (x < 0)
    for (int y = x; y <= 0 ; y ++)
      // Serial.println(y);
      motor.setSpeed(y);
      delay(ramp_down_speed);
    forward_power = 0;
    backward_power = 0;
void ramp_down_forward(int x)
  if (x > 0)
    for (int y = x; y >= 0 ; y --)
      //Serial.println(y);
      motor.setSpeed(y);
      delay(ramp_down_speed);//
    forward_power = 0;
    backward_power = 0;
PaulS
Code: [Select]
There are 3 variables involved in the conditions here, and you handle 2 of the 8 possible combinations. That leaves 6 un-handled. Not a good idea.
The names of most of your variables leaves a lot to be desired. Maybe they meant something to the original coder, but they mean nothing to me.
Quote
How is that supposed to work? Are the limit switches not actually at the end of the travel? Otherwise, how would triggering a limit switch allow time to slow down?
It's code tags, NOT quote tags.
ZipZoomFly
#2
May 17, 2019, 12:57 am Last Edit: May 17, 2019, 01:04 am by ZipZoomFly
@PaulS
Thanks - fixed the Quote/Code thing.
As to your other comments, well, the original coder (VERY nice guy) didn't speak much English, so yes, his nomenclature is a bit clunky.
Limit switches:
Very good observation! Yes, the limit switches are placed to allow continued movement of the device so that it can effectively coast to a stop. The physical setup keeps the limit switch triggered until the device moves fully away in the opposite direction.
As to the un-handled variables, well, I suppose this is what I'm looking for help with (I can make changes to the code, but I can't write it).
Thanks very much!
mugambi
#3
May 17, 2019, 01:07 am Last Edit: May 17, 2019, 01:09 am by mugambi
Good news
 i know your problem: the ramping up and down PWM is lowering voltage too much .
It is explained in a 2012 post on the forum
Quote
If you really are trying to run a 24V motor at a fraction of a volt then this is expected behaviour.   If the stall current is .75A at 24V then it should be taking about 11mA at 0.375V - the torque at that low current isn't enough to overcome static and dynamic friction so its only just running.
Using PWM from a higher voltage may improve matters but there is a fundamental issue here that you can't run a brushed DC motor at a tiny fraction of its design speed without friction being dominant.
from here
Bad news
Code must mostly be rewritten- which would also fix issues pointed out by @paulS
Quote
I can help with the rewrite, however, check PM
PaulMurrayCbr
#4
May 26, 2019, 06:51 am Last Edit: May 26, 2019, 07:02 am by PaulMurrayCbr
  • I have added code to introduce accelleration and dcelleration during normal running.
  • I have added code to add hysteresis to normal running speed. This may help with the stuttering.
  • I have added code to not invoke setSpeed() when the motor is already at the speed you want. Maybe this will also help the stuttering.
  • I have removed the ramp functions and the loops in them. Unnecessary: loop() is al the loop anyone needs.
  • I have removed extraneous variables.
Code: [Select]
//#include "CytronMotorDriver.h"
/** I don't have CytronMotorDriver.h, so I'll just rig up some  dummy variables*/
// ==== START OF DUMMY VARIABLES
const int PWM_DIR = 0;
class CytronMD {
  public:
    CytronMD(int a, int b, int c) {}
    void setSpeed(int) {}
// ==== END OF DUMMY VARIABLES
#define PWM 5
#define DIR 6
#define ramp_down_acceleration 10    //increasing the number will slow the ramp down process and vice versa
#define running_acceleration 50    //increasing the number will slow the rate of normal acelleration
#define running_noise_window 2 // this is the noise window *after* conversion from pot read to motor speed
const int SLS_Pin = 10; //Speed limit switch pin
bool BSW_state = 0;
bool FSW_state = 0;
bool ESW_state = 0;
int power = 0;
  motor.setSpeed(0);
  // emergency stop
  if (ESW_state == HIGH) {
    power = 0;
   // frobbing the emergency stop stops things for 1 second at least.
   // this give you time to twirl the pot to zero
  else {
    // handle stop switches
      power++;
      delay(ramp_down_acceleration);
      power--;
    // handle normal movement
    else {
      int target_power = get_direction();
      // if the target speed is zero, ignore the running noise window
      // and use "Stop!" acceleration.
      if (target_power == 0) {
        if (power > 0) power --;
        else if (power < 0) power ++;
        else {
          // no action needed - we are at the correct speed;
          return;
      else {
        // respect the limit switches. don't attempt to go back if the back limt switch is on
        if(target_power < 0 && BSW_state == LOW)
          return; // do nothing.
        if(target_power > 0 && FSW_state == LOW)
        // otherwise, acellerate within our noise window.
        // this means we never actually get to the target speed, but meh.
        // the operator of the train will just tweak the pot to get the speed they want
        if (target_power - power > running_noise_window) {
          power++;
        else if (target_power - power < running_noise_window) {
          power--;
        else {
          return;
        // otherwise, accelerate as required
        delay(running_acceleration);
int get_direction()
  if ((x < 511 + noise_window) && (x > 511 - noise_window))
    return 0;
  if (digitalRead(SLS_Pin) == HIGH)
  else if (digitalRead(SLS_Pin) == LOW)
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
