Topic: HC-05 Not working properly (Read 282 times) previous topic - next topic
Alexandr56
I have been trying to get my hc-05 connected to my laptop. Im using the tutorial in order to figure out if the hc-05 is working but once i get to the connection step by starting up the process code the module starts blinking twice every two seconds. Even when i do this the led does not light up. The code on the arduino is
Code: [Select]
char val; // variable to receive data from the serial port
int ledpin = 8; // LED connected to pin 48 (on-board LED)
  pinMode(ledpin, OUTPUT);  // pin 48 (on-board LED) as OUTPUT
  Serial.begin(38400);       // start serial communication at 9600bps
  if( Serial.available() )       // if data is available to read
    val = Serial.read();         // read it and store it in 'val'
  if( val == 'H' )               // if 'H' was received
    digitalWrite(ledpin, HIGH);  // turn ON the LED
    digitalWrite(ledpin, LOW);   // otherwise turn it OFF
  delay(100);                    // wait 100ms for next reading
The code on process 3 is
Code: [Select]
//import class to set up serial connection with wiring board
import processing.serial.*;
Serial port;
//button setup
color currentcolor;
RectButton rect1, rect2;
boolean locked = false;
  //set up window
  size(200, 200);
  color baseColor = color(102, 102, 102);
  currentcolor = baseColor;
  // List all the available serial ports in the output pane.
  // You will need to choose the port that the Wiring board is
  // connected to from this list. The first port in the list is
  // port #0 and the third port in the list is port #2.
  println(Serial.list());
  // Open the port that the Wiring board is connected to (in this case 1
  // which is the second open port in the array)
  // Make sure to open the port at the same speed Wiring is using (9600bps)
  port = new Serial(this, Serial.list()[0], 38400);
  // Define and create rectangle button #1
  int x = 30;
  int y = 100;
  int size = 50;
  color buttoncolor = color(153, 102, 102);
  color highlight = color(102, 51, 51);
  rect1 = new RectButton(x, y, size, buttoncolor, highlight);
  // Define and create rectangle button #2
  x = 90;
  y = 100;
  size = 50;
  buttoncolor = color(153, 153, 153);
  highlight = color(102, 102, 102);
  rect2 = new RectButton(x, y, size, buttoncolor, highlight);
void draw() {
  background(currentcolor);
  stroke(255);
  update(mouseX, mouseY);
  rect1.display();
  rect2.display();
void update(int x, int y) {
  if(locked == false) {
    rect1.update();
    rect2.update();
    locked = false;
  //Turn LED on and off if buttons pressed where
  //H = on (high) and L = off (low)
  if(mousePressed) {
    if(rect1.pressed()) {            //ON button
      currentcolor = rect1.basecolor;
      port.write('H');
    } else if(rect2.pressed()) {    //OFF button
      currentcolor = rect2.basecolor;
      port.write('L');
class Button {
  int x, y;
  int size;
  color basecolor, highlightcolor;
  color currentcolor;
  boolean over = false;
  boolean pressed = false;
  void update()
    if(over()) {
      currentcolor = highlightcolor;
      currentcolor = basecolor;
  boolean pressed()
    if(over) {
      locked = true;
      return true;
      locked = false;
      return false;
  boolean over()
    return true;
  void display()
class RectButton extends Button {
  RectButton(int ix, int iy, int isize, color icolor, color ihighlight)
    x = ix;
    y = iy;
    size = isize;
    basecolor = icolor;
    highlightcolor = ihighlight;
  boolean over()
    if( overRect(x, y, size, size) ) {
      over = true;
      return true;
      over = false;
      return false;
  void display()
    stroke(255);
    fill(currentcolor);
    rect(x, y, size, size);
boolean overRect(int x, int y, int width, int height) {
  if (mouseX >= x && mouseX <= x+width &&
      mouseY >= y && mouseY <= y+height) {
    return true;
    return false;
Nick_Pyner
#1
May 17, 2019, 12:56 am Last Edit: May 17, 2019, 06:36 am by Nick_Pyner
It may be just the wiring - Bluetooth<>Arduino. You can prove that code by leaving Arduino connected PC and sending the data from serial monitor.
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
