I have been trying to get my hc-05 connected to my laptop. Im using the
tutorial in order to figure out if the hc-05 is working but once i get to the connection step by starting up the process code the module starts blinking twice every two seconds. Even when i do this the led does not light up. The code on the arduino is
char val; // variable to receive data from the serial port
int ledpin = 8; // LED connected to pin 48 (on-board LED)
pinMode(ledpin, OUTPUT); // pin 48 (on-board LED) as OUTPUT
Serial.begin(38400); // start serial communication at 9600bps
if( Serial.available() ) // if data is available to read
val = Serial.read(); // read it and store it in 'val'
if( val == 'H' ) // if 'H' was received
digitalWrite(ledpin, HIGH); // turn ON the LED
digitalWrite(ledpin, LOW); // otherwise turn it OFF
delay(100); // wait 100ms for next reading
The code on process 3 is
//import class to set up serial connection with wiring board
import processing.serial.*;
Serial port;
//button setup
color currentcolor;
RectButton rect1, rect2;
boolean locked = false;
//set up window
size(200, 200);
color baseColor = color(102, 102, 102);
currentcolor = baseColor;
// List all the available serial ports in the output pane.
// You will need to choose the port that the Wiring board is
// connected to from this list. The first port in the list is
// port #0 and the third port in the list is port #2.
println(Serial.list());
// Open the port that the Wiring board is connected to (in this case 1
// which is the second open port in the array)
// Make sure to open the port at the same speed Wiring is using (9600bps)
port = new Serial(this, Serial.list()[0], 38400);
// Define and create rectangle button #1
int x = 30;
int y = 100;
int size = 50;
color buttoncolor = color(153, 102, 102);
color highlight = color(102, 51, 51);
rect1 = new RectButton(x, y, size, buttoncolor, highlight);
// Define and create rectangle button #2
x = 90;
y = 100;
size = 50;
buttoncolor = color(153, 153, 153);
highlight = color(102, 102, 102);
rect2 = new RectButton(x, y, size, buttoncolor, highlight);
void draw() {
background(currentcolor);
stroke(255);
update(mouseX, mouseY);
rect1.display();
rect2.display();
void update(int x, int y) {
if(locked == false) {
rect1.update();
rect2.update();
locked = false;
//Turn LED on and off if buttons pressed where
//H = on (high) and L = off (low)
if(mousePressed) {
if(rect1.pressed()) { //ON button
currentcolor = rect1.basecolor;
port.write('H');
} else if(rect2.pressed()) { //OFF button
currentcolor = rect2.basecolor;
port.write('L');
class Button {
int x, y;
int size;
color basecolor, highlightcolor;
color currentcolor;
boolean over = false;
boolean pressed = false;
void update()
if(over()) {
currentcolor = highlightcolor;
currentcolor = basecolor;
boolean pressed()
if(over) {
locked = true;
return true;
locked = false;
return false;
boolean over()
return true;
void display()
class RectButton extends Button {
RectButton(int ix, int iy, int isize, color icolor, color ihighlight)
x = ix;
y = iy;
size = isize;
basecolor = icolor;
highlightcolor = ihighlight;
boolean over()
if( overRect(x, y, size, size) ) {
over = true;
return true;
over = false;
return false;
void display()
stroke(255);
fill(currentcolor);
rect(x, y, size, size);
boolean overRect(int x, int y, int width, int height) {
if (mouseX >= x && mouseX <= x+width &&
mouseY >= y && mouseY <= y+height) {
return true;
return false;
