Topic: MPU6050 Rx and Tx Car gets stuck in Forward or Backward (Read 76 times) previous topic - next topic
Marciokoko
I have this 4wd car platform and Im using these as the Rx and Tx sketches.  The car uses an Arduino UNO with an L293D driver shield with a RF433Mhz Rx module.  The UNO is powered from a 9V barrel jack and the Motors are powered from 4xAA battery pack.  The Rx is a nano with a 433Mhz Rx and an MPU6050 module, powered from a mobile phone battery pack.
The problem
If I tilt the MPU6050 left or right, the car correctly turns either 1 wheel or the other, to make it turn.  As soon as I return to the "flat" position it stops turning.  But when I tilt the MPU6050 to the back or front, it correctly runs forward or backward but it never stops after that.
Here is the Rx:
Code: [Select]
// Include RadioHead Amplitude Shift Keying Library
#include <RH_ASK.h>
// Include dependant SPI Library
#include <SPI.h>
#include <AFMotor.h>
// Create Amplitude Shift Keying Object
RH_ASK rf_driver;
//Define packet for the direction (X axis and Y axis)
int data[2];
AF_DCMotor motor1(1, MOTOR12_64KHZ); // create motor #1, 64KHz pwm
AF_DCMotor motor2(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
AF_DCMotor motor3(3, MOTOR12_64KHZ); // create motor #3, 64KHz pwm
AF_DCMotor motor4(4, MOTOR12_64KHZ); // create motor #4, 64KHz pwm
String str_out;
  rf_driver.init();
  motor1.setSpeed(200);     // set the speed to 200/255
  motor2.setSpeed(200);     // set the speed to 200/255
  motor3.setSpeed(200);     // set the speed to 200/255
  motor4.setSpeed(200);     // set the speed to 200/255
// Set buffer to size of expected message
    int receivedData[3] = {0};
    uint8_t buflen = sizeof(receivedData);
    if (rf_driver.recv((uint8_t*)receivedData, &buflen)) {
      //if data is not an array, use &receivedData
    for (byte i = 0; i < 3; i++) {
    if(receivedData[0] > 380){
      left();
      Serial.println("LEFT"); //motor back left
    if(receivedData[0] < 310){
      right();
      Serial.println("RIGHT"); //motor back right
    if(receivedData[1] > 180){
      forward();
      Serial.println("FORWARD"); //motor bl and br direction 1
    if(receivedData[1] < 110){
      backward();
      Serial.println("BACKWARD"); //motor bl and br direction 2
    if(receivedData[0] > 330 && receivedData[0] < 360 && receivedData[1] > 130 && receivedData[1] < 160){
      //brake();
      stopCar();
      Serial.println("STOP");
void forward(){
  Serial.println("running forward");
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(FORWARD);
  motor4.run(FORWARD);
void backward(){
  Serial.println("running backward");
  motor1.run(BACKWARD);
  motor2.run(BACKWARD);
  motor3.run(BACKWARD);
  motor4.run(BACKWARD);
void left(){
void right(){
void brake(){
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
void stopCar(){
And the Tx code:
Code: [Select]
#include <RH_ASK.h>
#include <SPI.h>
#include "Wire.h"       //For communicate
#include "I2Cdev.h"     //For communicate with MPU6050
#include "MPU6050.h"    //The main library of the MPU6050
//Define the object to access and cotrol the Gyro and Accelerometer (We don't use the Gyro data)
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int data[2];
RH_ASK rf_driver;
  mpu.initialize();              //Initialize the MPU object
  // Initialize ASK Object
  rf_driver.init();
  delay(2000);
  //With this function, the acceleration and gyro values of the axes are taken.
  //If you want to control the car axis differently, you can change the axis name in the map command.
  mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
    //In two-way control, the X axis (data [0]) of the MPU6050 allows the robot to move forward and backward.
  //Y axis (data [0]) allows the robot to right and left turn.
  data[0] = map(ax, -17000, 17000, 300, 400 ); //Send aX axis data
  data[1] = map(ay, -17000, 17000, 100, 200);  //Send aY axis data
  rf_driver.send((const uint8_t*)data, sizeof(data));
  //(uint8_t *)msg, strlen(msg));
  rf_driver.waitPacketSent();
  Serial.println(data[0]);
  Serial.println(data[1]);
If you think it necessary to post pictures of the car and wiring I will, but I dont think it would be very clear.  Id upload a sketch but I dont think the wiring is the issue because it seems to me its a coding issue rather than a wiring issue.
