Topic: how to make counter in this phase ? (Read 302 times) previous topic - next topic
heshammo
May 18, 2019, 01:40 pm Last Edit: May 18, 2019, 02:41 pm by heshammo
i have 3 button  i made 2 switch up and down to control on motor  i want to control them by last button to turn off  their function  when i pushed it high , make them turn actuator up and down and all this showed on LCD ?
Code: (c++) [Select]
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);           // select the pins used on the LCD panel
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
int a  = 11;
int b  = 12;
int c = 13;
int d = A4;
int val = 0;
int counter = 0;
int currentState = 0;
int previousState = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
#define Bck       10
int read_LCD_buttons(){               // read the buttons
   adc_key_in = analogRead(0);       // read the value from the sensor
   // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
   // we add approx 50 to those values and check to see if we are close
   // We make this the 1st option for speed reasons since it will be the most likely result
   if (adc_key_in > 1000) return btnNONE;
    if (adc_key_in < 50)   return btnRIGHT;
    if (adc_key_in < 195)  return btnUP;
    if (adc_key_in < 380)  return btnDOWN;
    if (adc_key_in < 555)  return btnLEFT;
    if (adc_key_in < 790)  return btnSELECT;
   return btnNONE;                // when all others fail, return this.
int voltPin=A5;
// it's a 16x2 LCD so...
int screenWidth = 16;
int screenHeight = 2;
// the two lines
// line1 = scrolling
String line1 = "Easy Life Company - 01001004863";
String line2 = " Whizzzkid Inc. ";
// just some reference flags
int stringStart, stringStop = 0;
int scrollCursor = screenWidth;
 pinMode(Bck,OUTPUT);
 pinMode(a,OUTPUT); //13
 pinMode(b,OUTPUT);//12
 pinMode(c,OUTPUT);
 pinMode(d,OUTPUT);
 pinMode(btnRIGHT,INPUT);
 lcd.begin(16, 2);               // start the library
 lcd.setCursor(0,0);             // set the LCD cursor   position
 analogWrite(Bck,255);
  lcd_key = read_LCD_buttons();   // read th
  if (lcd_key == btnDOWN && lcd_key == btnUP&& lcd_key == btnRIGHT  )
            { lcd.setCursor(0,1);
              lcd.print("Eror                ");  //  push button "DOWN" and show the word on the screen
              digitalWrite(a,LOW);
              digitalWrite(b,LOW);
              digitalWrite(c,LOW);
              digitalWrite(d,LOW);
  else if (lcd_key == btnUP)
            lcd.setCursor(0,1);
              lcd.print("Up Stairs                ");  //  push button "UP" and show the word on the screen
              digitalWrite(a,HIGH);
  else if (lcd_key == btnDOWN)
             lcd.setCursor(0,1);
            lcd.print("Down Stairs                ");  //  push button "DOWN" and show the word on the screen
            digitalWrite(b,HIGH);
             else if (lcd_key == btnRIGHT){
              lcd.setCursor(0,1);
             lcd.print("actuator mode                ");  //  push button "UP" and show the word on the screen
             currentState = 1;
             lcd.setCursor(0,1);
             lcd.print("actuator up                ");  //  push button "DOWN" and show the word on the screen
             digitalWrite(d,HIGH);
             lcd.setCursor(0,1);
             lcd.print("actuator down                ");  //  push button "DOWN" and show the word on the screen
else if (lcd_key ==btnNONE )
              lcd.setCursor(scrollCursor, 1);
 lcd.print(line1.substring(stringStart,stringStop));
 delay(300);
 lcd.clear();
 if(stringStart == 0 && scrollCursor > 0){
   scrollCursor--;
   stringStop++;
 } else if (stringStart == stringStop){
   stringStart = stringStop = 0;
 } else if (stringStop == line1.length() && scrollCursor == 0) {
   stringStart++;
   stringStart++;
   stringStop++;
           // lcd.setCursor(0,1);
            lcd.print("Break!                        ");
            //lcd.print();
float val = analogRead(voltPin);
float VoltRead= map(val, 346, 679, 18.4, 37);
//lcd.print(VoltRead);
//lcd.print("  ");
//lcd.print(val);
///////////////////////////////////                   //TESTING PATTERNS
  if(VoltRead<23)               /////Less than 23
   lcd.setCursor(0,0);
  lcd.print("Battery:");
   lcd.setCursor(9,0);
   lcd.print("20%");}
AWOL
Please don't cross post.
Duplicate deleted.
Please remember to use code tags when posting code
heshammo
AWOL
#3
May 18, 2019, 02:48 pm Last Edit: May 18, 2019, 02:48 pm by AWOL
please help me   :)
Can I introduce you to the IDE's auto-format tool?
It makes visualisation of the structure of your code much easier.
heshammo
#4
May 18, 2019, 03:04 pm Last Edit: May 18, 2019, 03:15 pm by heshammo
i used it but i miss understand what do you mean  :(
int lcd_key     = 0;
int adc_key_in  = 0;
int Pulse  = 11;
int Dir  = 12;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
#define Bck       10
long delay_Micros = 1800; // Set value
long currentMicros = 0; long previousMicros = 0;
int read_LCD_buttons() {              // read the buttons
int voltPin = A5;
// the two lines
  pinMode(Bck, OUTPUT);
  pinMode(Pulse, OUTPUT); //13
  pinMode(Dir, OUTPUT); //12
  lcd.setCursor(0, 0);            // set the LCD cursor   position
  analogWrite(Bck, 255);
  digitalWrite(Dir, LOW);
  currentMicros = micros();
  lcd_key = read_LCD_buttons();   // read the buttons
  if (lcd_key == btnDOWN && lcd_key == btnUP)
  { lcd.setCursor(0, 1);
    lcd.print("Eror                ");//  push button "DOWN" and show the word on the screen
    digitalWrite(Pulse, LOW);
  else if (lcd_key == btnUP )
    currentMicros - previousMicros >= delay_Micros;
    previousMicros = currentMicros;
    digitalWrite(Dir, HIGH);
    digitalWrite(Pulse, HIGH);
    delayMicroseconds(50);
    delayMicroseconds(50); //Set Value
  else if (lcd_key == btnNONE )
    lcd.print(line1.substring(stringStart, stringStop));
    delay(300);
    lcd.clear();
    if (stringStart == 0 && scrollCursor > 0) {
      scrollCursor--;
      stringStop++;
    } else if (stringStart == stringStop) {
      stringStart++;
      stringStart++;
      stringStop++;
    //lcd.print();
    float VoltRead = map(val, 346, 679, 18.4, 37);
    //lcd.print("  ");
    //lcd.print(val);
//delay(100);}
UKHeliBob
Code: [Select]
How likely is it that lcd_key will equal two different values at the same time ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
