Topic: Randomly Alternate LED pins (Read 959 times) previous topic - next topic
tekjones9
The pin numbers are in an array
The array indices are 0 and 1
You need to generate a random number that is either 0 or 1 to use as the index to the array
Code: [Select]
random(0, 1);
does not generate a random number that is either 0 or 1.  Print it to see what it does generate
Well, changing it to ledPin1=myPins[random(o,2)]; which should generate a value between 0 and 1 does not actually fix the problem so what is wrong?
PaulRB
#16
May 29, 2019, 08:02 pm Last Edit: May 29, 2019, 08:03 pm by PaulRB
More errors here:
Code: [Select]
ledPin1 = myPins[random(0,2)];
if(ledPin1 = 0){
  int ledPin2 = 1;}
  else {
    int ledPin2 = 0;}
What value could ledPin1 be here? Should it ever be zero?
It's important to understand the difference between "=" and "=="
tekjones9
Thank you to everyone for your helpful comments. This isn't a programming language I have used much before so the little things become frustratingly invisible.
Below is the code that achieves my desired output for any future reference:
Code: [Select]
unsigned long previousMillisLED10 = 0; //millis() returns an unsigned long
unsigned long previousMillisLED11 = 0; //millis() returns an unsigned long
unsigned long intervalLED10 = 100; //time needed to wait (ms) - 10 Hz
unsigned long intervalLED11 = 1; //1 kHz
boolean LED10State = false; //state variable for LED
boolean LED11State = false;
int ledPin1;
int ledPin2;
  // put your setup code here, to run once
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
int myPins[]={10, 11};
randomSeed(analogRead(A0));
   if(ledPin1 == 10){
  ledPin2 = 11;}
  else if (ledPin1 == 11){
    ledPin2 = 10;}
Serial.print("Pin 1: " );
Serial.println(ledPin1);
Serial.print("Pin 2: " );
Serial.println(ledPin2);
unsigned long currentMillis = millis(); //grab current time
//toggle LED10
if ((unsigned long)(currentMillis-previousMillisLED10)>= intervalLED10){
  LED10State =!LED10State; //toggles the state
  digitalWrite(ledPin1, LED10State); //sets the LED based on ledState
  //save the 'current' time to pin 10's previousMillis
  previousMillisLED10 = currentMillis;
//toggle LED11
if ((unsigned long)(currentMillis-previousMillisLED11)>= intervalLED11){
  LED11State =!LED11State; //toggles the state
  digitalWrite(ledPin2, LED11State); //sets the LED based on ledState
  //save the 'current' time to pin 11's previousMillis
  previousMillisLED11 = currentMillis;
