Topic: executar açao apenas uma vez dentro do loop (SOU INICIANTE) (Read 433 times) previous topic - next topic
Vitor_Brzozkowski
#15
May 25, 2019, 02:20 am Last Edit: May 25, 2019, 02:24 am by Vitor_Brzozkowski
Code: [Select]
boolean acionaRele = true;/******************************************************************************/
int i;
int sign;
long value;
float result;
int clockpin = 4;
int datapin = 5;
int releX = 13;
int rele11 = 11;
int rele2 = 10;
int rele22 = 9;
int rele3 = 8;
int rele33 = 7;
unsigned long tempmicros;
  pinMode(clockpin, INPUT);
  pinMode(datapin, INPUT);
  pinMode(releX, OUTPUT);
  pinMode(rele2, OUTPUT);
  pinMode(rele3, OUTPUT);
  pinMode(rele11, OUTPUT);
  pinMode(rele22, OUTPUT);
  pinMode(rele33, OUTPUT);
void loop () {
  while (digitalRead(clockpin) == HIGH) {} //if clock is LOW wait until it turns to HIGH
  tempmicros = micros();
  while (digitalRead(clockpin) == LOW) {} //wait for the end of the HIGH pulse
  if ((micros() - tempmicros) > 500) { //if the HIGH pulse was longer than 500 micros we are at the start of a new bit sequence
    decode(); //decode the bit sequence
void decode() {
  sign = 1;
  value = 0;
  for (i = 0; i < 23; i++) {
    while (digitalRead(clockpin) == HIGH) { } //wait until clock returns to HIGH- the first bit is not needed
    while (digitalRead(clockpin) == LOW) {} //wait until clock returns to LOW
    if (digitalRead(datapin) == LOW) {
      if (i < 20) {
        value |= 1 << i;
      if (i == 20) {
        sign = -1;
  result = (value * sign) / 3856.8376068376;
  Serial.println(result, 2); //print result with 2 decimals
  delay(5);
  if ( result > 2.12 && result < 2.45 ) {
    if (acionaRele == true){
      digitalWrite(releX, HIGH);
      digitalWrite(releX, LOW);
delay(10);
 acionaRele = false;
  else {
acionaRele = true;
esta funcionando assim, mas so com 1 das tolerancias, se eu adicionar mais uma.
 exemplo:
Code: [Select]
delay(10);
 acionaRele = false;
  else {
acionaRele = true;
  if ( result > 2.45 && result < 3.19 ) {
delay(10);
 acionaRele = false;
  else {
acionaRele = true;
o codigo entra em loop, e pisca ligando e desligando o rele (eu entendo o pq do loop mas nao sei escrever algo que pare isso)
tecdiego
Testa aí
Code: [Select]
#define acoplador 13
int intervaloRele;/******************************************************************************/
int i;
int sign;
long value;
float result;
int clockpin = 4;
int datapin = 5;
int tempo_de_acopl = 5000;
int rele1 = 12;
int rele11 = 11;
int rele2 = 10;
int rele22 = 9;
int rele3 = 8;
int rele33 = 7;
  pinMode(rele1, OUTPUT);
  pinMode(acoplador,OUTPUT);
void loop () {
void decode() {
  sign = 1;
  value = 0;
      if (i < 20) {
        value |= 1 << i;
      if (i == 20) {
        sign = -1;
  delay(5);
  if ((intervaloRele + 3000) <= millis()){
    digitalWrite(rele1, LOW);
    digitalWrite(rele11, HIGH);
    acionaRele = true;
      digitalWrite(rele1, HIGH);
      digitalWrite(rele11, LOW);
      acionaRele = false;
      intervaloRele = millis();
  else {
    digitalWrite(rele3, HIGH);
    digitalWrite(rele33, HIGH);
  else {
    digitalWrite(rele3, LOW);
 if ( result > 2.12 && result < 3.19 ) {
    digitalWrite(rele2, LOW);
     digitalWrite(rele22, HIGH);
  else {
    digitalWrite(rele2, HIGH);
     digitalWrite(rele22, LOW);
  acopl ();
acopl ();
 if ( result > 0.00 && result < 2.12) {
  acopl ();
 if ( result > 3.19 && result < 10.00) {
  acopl ();
void acopl() {
digitalWrite(acoplador, HIGH);
delay(tempo_de_acopl);
digitalWrite(acoplador, LOW);
Vitor_Brzozkowski
#17
May 25, 2019, 08:31 pm Last Edit: May 25, 2019, 08:39 pm by Vitor_Brzozkowski
Testa aí
Code: [Select]
int i;
int sign;
long value;
float result;
int clockpin = 4;
int datapin = 5;
int rele1 = 12;
int rele11 = 11;
int rele2 = 10;
int rele22 = 9;
int rele3 = 8;
int rele33 = 7;
void loop () {
void decode() {
  sign = 1;
  value = 0;
      if (i < 20) {
        value |= 1 << i;
      if (i == 20) {
        sign = -1;
  delay(5);
    acionaRele = true;
      acionaRele = false;
  else {
  else {
  else {
  acopl ();
acopl ();
  acopl ();
  acopl ();
void acopl() {
Bah não funcionou, acho q vou desistir do projeto, esse q você me mandou deixa ligado continuamente igual o anterior, mas obrigado pela ajuda, o problema agora é quando coloco mais 1 tolerância ele trava o sistema, pensei em usar goto mas aí ele ia só ficar reiniciando e ligaria novamente o relé , tem como usar 1 "else" para vários "If"?
tecdiego
Diz oq você quer fazer! Assim podemos fazer o código do zero!
