Topic: ultrasonic sensor and line follower robot (Read 565 times) previous topic - next topic
safa_1997
May 23, 2019, 04:54 am Last Edit: May 23, 2019, 05:03 am by safa_1997
hello everyone :D
i have a problem with my ultrasonic sensor , i don't know why it doesn't work but for me it sems that a code problem
my project is to creat a line follower robot: for that i use 2 motors and 4 infrared sensor ..
my robot suppose to stop when the 4 sensors in black OR the ultrsonic sensor detects an obstacle in 10 cm
when i put the code for just  following line it works perfectliy but when i add the ultrasonic never work and
he don't follows  the line anymore
can you please help me
Code: [Select]
#include <NewPing.h>
// Déclaration des constantes et variables
// capteur de distance
#define trigPin   12  //  Pin Trigger branchée sur la broche 12 de l'arduino
#define echoPin   11  //  Pin Echo branchée sur la broche 11 de l'arduino
NewPing sonar(trigPin, echoPin);
int maximumDistance = 50;  // distance Maximale acceptée (de 0-450 cm)
int minimumDistance = 0;   // distance Minimale acceptée (en cm)
int cm = 0;
boolean PasObstacle = true;   // valeur à O ou true si pas d'obstacle détecté  sinon la valeur prend 1
const int distanceObstacle = 10; //  Distance de détection d'un obstable : ici 15 cm
int distance = 0;
int attenteCateur = 200;
//définition des bouttons
int button1=1;  //vert
int button=2;   //rouge
int z;
int w;
int cap1=3;
int cap2=4;
int cap3=5;
int cap4=6;
int varmot2=9;
int av2=7;       //avant
int ar2=8;       //arrière
int varmot1=14;
int av1=15;       //avant
int ar1=16;
boolean a;
boolean b;  //les deux capteurs au milieu
boolean c; //les deux capteurs au milieu
boolean d;
boolean stope;
boolean left;
boolean right;
boolean forward;
boolean backward;
  // dir.attach(13);
   //dir.write(90);
  pinMode(varmot1,OUTPUT);
  pinMode(av1,OUTPUT);
  pinMode(ar1,OUTPUT);
  pinMode(varmot2,OUTPUT);
  pinMode(av2,OUTPUT);
  pinMode(ar2,OUTPUT);
pinMode(button,INPUT);
  pinMode(button1,INPUT);
  int val1,val2,val3,val4 ;
  val1 = digitalRead(cap1) ;
    a = val1 ;                  //< 500;
  val2 = digitalRead(cap2) ;
    b = val2 ;                   //< 500;
  val3 = digitalRead(cap3) ;
    c = val3 ;                  //< 500;
  val4 = digitalRead(cap4) ;
    d = val4 ;                   //< 500;
 right=           (((!a)&&(d))&&(c||(!b)));   //(((!b)&&(!a))&& d);
 left=            ((a&&(!d))&&(b||(!c)));   //(((!d)&& a) &&(!c));
 backward=   (((!a)&&(!c))&&((!b)&&(!d)));      //||(b&&d)))||((!b)&&(!d)&&a&&c);
 forward=   ((!a)&&(b)&&(c)&&(!d));       //||(a&&d)))||(a&&(!b)&&(!c)&&d);
 stope=     (a&&b&&c&&d);
 lecture ();
   distance =  mesureDistance();  // on lit la valeur en cm
if (PasObstacle)  {
  z=digitalRead(1);
 w=digitalRead(2);
 if ((stope)&&(w==1))
  droite ();
else if ((stope)&&(z==1))
avant();
  if (left)
    gauche () ;
  else if (right)
      droite();
  else if (forward)
    avant();
 else if (backward)
    arrier ();
  else if (stope)
  stopp();}
    stopp();}
unsigned int mesureDistance() {
  // déclaration des variables locales
  int  cm = sonar.ping_cm();
  if (cm > distanceObstacle || cm  <= minimumDistance) {
    PasObstacle =  true;  // on renvoie true s'il n'y pas d'obstacle
  else  {
    PasObstacle = false;  // on renvoie false s'il y a un obstacle
  return cm; // retourne la distance du capteur en cm
void lecture ()
    Serial.print(a);
    Serial.print(b);
    Serial.print(c);
    Serial.println(d);
void gauche ()
    analogWrite(varmot1,100);
    digitalWrite(av1,0);
    digitalWrite(ar1,0);
    //dir.write(50);
    analogWrite(varmot2,255);
    digitalWrite(av2,1);
    digitalWrite(ar2,0);
void droite ()
    analogWrite(varmot1,255);
    digitalWrite(av1,1);
    //dir.write(130);
  analogWrite(varmot2,100);
    digitalWrite(av2,0);
void avant ()
    analogWrite(varmot1,250);
    digitalWrite(av2,HIGH);
    digitalWrite(ar2,LOW);
    //dir.write(90);
    analogWrite(varmot2,250);
void arrier ()
    analogWrite(varmot1,150);
    digitalWrite(av2,LOW);
    digitalWrite(ar2,HIGH);
    analogWrite(varmot2,150);
    digitalWrite(ar1,1);
void stopp ()
    digitalWrite(av1,LOW);
    digitalWrite(ar1,LOW);
Grumpy_Mike
Given that
Code: [Select]
The code
Code: [Select]
Will always be true. Would you mean to AND those two statements and not OR them?
That is && in place of ||
wvmarle
Please format your code properly before posting, the autoformat function of the IDE  can help out.
This doesn't make sense:
Code: [Select]
  a = val1 ;                  //< 500;
- you declare a local variable, an int,
- use that to store a 1 or a 0, depending on what the digitalRead() returns,
- then store that in a global bool, not using the local int any more.
Yes it works, no it's not good practice. Just declare four bools there, and use them to store the pin state.
Code: [Select]
The comment is even less readable as what you're doing here... and you are probably looking for the & operator, not the && operator. I'm sure these lines can be done in a readable manner. Or at least use comments that tell what is going on, not something that makes the Perl syntax look good.
Code: [Select]
And then you do nothing with the distance, but you do look at the global bool PasObstacle.
Code: [Select]
  z=digitalRead(1);
Bad idea: that's the Serial interface. Don't use pins 0 and 1 unless you really don't have any others (and know what you're doing).
All in all the code is such a mess that I can't tell more than just these oddities. A reformat will go a long way making it readable and understandable. Actually using variables that you declare (like the button pin numbers) would be another great improvement.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
wvmarle
Given that
Code: [Select]
The code
Code: [Select]
cm <= minimumDistance is false unless cm = 0. So it's pretty much redundant in this situation.
The thing evaluates to true the moment cm > distanceObstacle is true, which would be cm > 10. That's sensible. Then the PasObstacle is set true, and the normal movement is done. To me this part actually looks correct.
safa_1997
#4
May 23, 2019, 06:00 pm Last Edit: May 23, 2019, 06:04 pm by safa_1997
i am sorry for the bad comments in the code  i just write them when i am testing
this my new code after reading your comments .. but nothing change .. he doesn't work
 thank you very much for the reponse
Code: [Select]
// capteur ultrasonic
int cm = 0; //declare une variable cm qui je l'utilise dans la comparaison
boolean PasObstacle;
const int distanceObstacle =10; //  Distance de détection d'un obstable : ici 10 cm
int distance = 0;
int button1=20;  //vert
int button=21;   //rouge
int z;
int w;
// définition des capteur ultrason
int cap1=3;  // cap gauche
int cap2=4;  // cap milieu
int cap3=5;  // cap milieu
int cap4=6;  // cap droite
// definition de boche de la carte de puissance
int varmot2=9;
int av2=7;       //avant
int varmot1=14;
int av1=15;       //avant
int ar1=16;
boolean a;
boolean b;//les deux capteurs au milieu
boolean c;//les deux capteurs au milieu
boolean d;
boolean stope;// j'ecrit stope à la fin "e" car tt simplement lorque j'ecrit stop elle devient en rouge don je pense que c'est une fonction prédifine.
boolean left;
boolean right;
boolean forward;
boolean backward;
 a = digitalRead(cap1) ; // a recoi la valeur de cap1 (1 ou 0)
  b = digitalRead(cap2) ;// b recoi la valeur de cap2 (1 ou 0)
 c = digitalRead(cap3) ;// c recoi la valeur de cap3  (1 ou 0)
 d = digitalRead(cap4) ;// d recoi la valeur de cap4 (1 ou 0)
 right=(((!a)&&(d))&&(c||(!b)));  // le robot doit tourner à droite lorsque la condition est vrai c'est à dire ( le capteur à droite est en noir OU bien le capteur droite ET le milieu en noir )
 left=((a&&(!d))&&(b||(!c)));   // le robot doit tourner à gauche lorsque la condition est vrai c'est à dire ( le capteur à gauche est en noir OU bien le capteur gauche ET le milieu  en noir )
 backward=(((!a)&&(!c))&&((!b)&&(!d))); // le robot doit étre marche en arriére lorsque il sort de map c'est à dire les 4 capteur en blanc
 forward=((!a)&&(b)&&(c)&&(!d)); // le robot doit étre marche en avant lorsque le 2 capteur au milieu est en noir
 stope=(a&&b&&c&&d);// le robot fait un stop lorsque les 4 capteur en noir
 lecture ();// fonction pour just affichier le valeur des capteur en moniteur série
if (PasObstacle)  {
  z=digitalRead(20);
 w=digitalRead(21);
 if ((stope)&&(w==1)) // si le robot est en stop est on appui sue le bouton rouge il tourne droite
  droite ();
else if ((stope)&&(z==1))  // si le robot est en stop est on appui sue le bouton vert rouge il marche avant
avant();
  if (left)
    gauche () ;
  else if (right)
      droite();
  else if (forward)
    avant();
 else if (backward)
    arrier ();
  else if (stope)
  stopp();}
    stopp();}
unsigned int mesureDistance() { // fonctin pour comparer la distance calculé avec la distanceobstacle
  if (cm > distanceObstacle) {
  else  {
void lecture ()
    Serial.print(a);
    Serial.print(b);
    Serial.print(c);
    Serial.println(d);
void gauche ()
void droite ()
void avant ()
void arrier ()
void stopp ()
safa_1997
Given that
Code: [Select]
The code
Code: [Select]
i just want that my robot stop when the distance <10
wvmarle
Please start by making your code readable, as I requested in #2.
Some decent formatting, remove unnecessary whitelines, that kind of things. It helps a lot in finding out what it does and where it goes wrong.
safa_1997
#7
May 23, 2019, 07:42 pm Last Edit: May 23, 2019, 08:10 pm by safa_1997
Code: [Select]
const int distanceObstacle = 10; //  Distance de détection d'un obstable : ici 10 cm
int distance = 0;
int button1 = 20; //vert
int button = 21; //rouge
int z;
int w;
int cap1 = 3; // cap gauche
int cap2 = 4; // cap milieu
int cap3 = 5; // cap milieu
int cap4 = 6; // cap droite
int varmot2 = 9;
int av2 = 7;     //avant
int ar2 = 8;     //arrière
int varmot1 = 14;
int av1 = 15;     //avant
int ar1 = 16;
boolean a;
boolean d;
boolean left;
boolean right;
boolean forward;
boolean backward;
  pinMode(varmot1, OUTPUT);
  pinMode(av1, OUTPUT);
  pinMode(ar1, OUTPUT);
  pinMode(varmot2, OUTPUT);
  pinMode(av2, OUTPUT);
  pinMode(ar2, OUTPUT);
  pinMode(button, INPUT);
  pinMode(button1, INPUT);
  right = (((!a) && (d)) && (c || (!b))); // le robot doit tourner à droite lorsque la condition est vrai c'est à dire ( le capteur à droite est en noir OU bien le capteur droite ET le milieu en noir )
  left = ((a && (!d)) && (b || (!c))); // le robot doit tourner à gauche lorsque la condition est vrai c'est à dire ( le capteur à gauche est en noir OU bien le capteur gauche ET le milieu  en noir )
  backward = (((!a) && (!c)) && ((!b) && (!d))); // le robot doit étre marche en arriére lorsque il sort de map c'est à dire les 4 capteur en blanc
  forward = ((!a) && (b) && (c) && (!d)); // le robot doit étre marche en avant lorsque le 2 capteur au milieu est en noir
  stope = (a && b && c && d); // le robot fait un stop lorsque les 4 capteur en noir
  if (PasObstacle)  {
    z = digitalRead(20);
    w = digitalRead(21);
    if ((stope) && (w == 1)) // si le robot est en stop est on appui sue le bouton rouge il tourne droite
      droite ();
    else if ((stope) && (z == 1)) // si le robot est en stop est on appui sue le bouton vert rouge il marche avant
      avant();
    if (left)
      gauche () ;
    else if (right)
      droite();
    else if (forward)
      avant();
    else if (backward)
      arrier ();
    else if (stope)
      stopp();
    stopp();
  else  {
void lecture ()
  Serial.print(a);
  Serial.print(b);
  Serial.print(c);
  Serial.println(d);
void gauche ()
  analogWrite(varmot1, 100);
  digitalWrite(av1, 0);
  digitalWrite(ar1, 0);
  analogWrite(varmot2, 255);
  digitalWrite(av2, 1);
  digitalWrite(ar2, 0);
void droite ()
  analogWrite(varmot1, 255);
  digitalWrite(av1, 1);
  analogWrite(varmot2, 100);
  digitalWrite(av2, 0);
void avant ()
  analogWrite(varmot1, 250);
  digitalWrite(av2, HIGH);
  digitalWrite(ar2, LOW);
  analogWrite(varmot2, 250);
void arrier ()
  analogWrite(varmot1, 150);
  digitalWrite(av2, LOW);
  digitalWrite(ar2, HIGH);
  analogWrite(varmot2, 150);
  digitalWrite(ar1, 1);
void stopp ()
  digitalWrite(av1, LOW);
  digitalWrite(ar1, LOW);
Grumpy_Mike
Quote
but the
with
means it won't.
safa_1997
but the
with
means it won't.
i change that !
 i put cm<=sonar.ping_cm();
  else  {
can you please check my post #7?
safa_1997
#11
May 23, 2019, 11:26 pm Last Edit: May 24, 2019, 12:08 am by safa_1997
Also here
is that a problem that i ask the same question in frensh  ?
 i just need some help.. but it seems that i am wasting your time and mine too
ps :I am beginner .. I am not professional with the arduino ..
when i first see your comment  and you put a link.. i just think  it's a useful link or a solution hh..it's very painful when you are full of stress and you are doing your best in a project and you call some help and get comments like this..
anyway  thank you very much and sorry for the  disturbance  i will find my solution alone  :)
AWOL
#12
May 24, 2019, 09:16 am Last Edit: May 24, 2019, 09:27 am by AWOL
I have no problems with you posting in different languages, but it would be polite to inform people that you have done so.
Quote
Me neither.
safa_1997
I don't see that posting another post is impolite behavior!! and i think that nobody will mind ! Anyway, as I say I solved the problem by myself and I decide to share my new code for other people that may have my same problem
Code: [Select]
#define trigPin   24  //  Pin Trigger branchée sur la broche 12 de l'arduino
#define echoPin   25  //  Pin Echo branchée sur la broche 11 de l'arduino
int distance = 0;
//Define Pins
int button1 = 22; //vert
int button = 23; //rouge
int z=0;
int w=0;
int ENA = 3; //Enable Pin of the Right Motor (must be PWM)
int IN1 = 7; //Control Pin
int IN2 = 2;
int ENB = 6; //Enable Pin of the Left Motor (must be PWM)
int IN3 = 4;
int IN4 = 5;
//Speed of the Motors
#define ENASpeed 250
#define ENBSpeed 250
int Sensor1 = 0;
int Sensor2 = 0;
int Sensor3 = 0;
int Sensor4 = 0;
  pinMode(ENA, OUTPUT);
  pinMode(IN1, OUTPUT);
  pinMode(IN2, OUTPUT);
  pinMode(ENB, OUTPUT);
  pinMode(IN3, OUTPUT);
  pinMode(IN4, OUTPUT);
  pinMode(Sensor1, INPUT);
  pinMode(Sensor2, INPUT);
  pinMode(Sensor3, INPUT);
  pinMode(Sensor4, INPUT);
  //Use analogWrite to run motor at adjusted speed
  analogWrite(ENA, ENASpeed);
  analogWrite(ENB, ENBSpeed);
  //Read the Sensor if HIGH (BLACK Line) or LOW (WHITE Line)
  Sensor1 = digitalRead(10);
  Sensor2 = digitalRead(11);
  Sensor3 = digitalRead(12);
  Sensor4 = digitalRead(13);
  z = digitalRead(22);
  w = digitalRead(23);
  //Set conditions for FORWARD, LEFT and RIGHT
if (PasObstacle)  {
  if (Sensor4 == HIGH && Sensor3 == LOW && Sensor2 == LOW && Sensor1 == LOW)
    //Turn LEFT
    //motor A Backward
    digitalWrite(IN1, HIGH);
    digitalWrite(IN2, LOW);
    //motor B Forward
    digitalWrite(IN3, LOW);
    digitalWrite(IN4, LOW);
  else if (Sensor4 == LOW && Sensor3 == LOW && Sensor2 == LOW && Sensor1 == HIGH)
      //Turn RIGHT
    //motor A Forward
    digitalWrite(IN1, LOW);
    //motor B Backward
    digitalWrite(IN3, HIGH);
  else if (Sensor4 == HIGH && Sensor3 == HIGH && Sensor2 == HIGH && Sensor1 == HIGH)
       if  (w == 1)
    //Turn RIGHT
    //motor A Forward
    //motor B Backward
   else  if  (z == 1)
 else {
    // stop
  else if (Sensor4 == LOW && Sensor3 == LOW && Sensor2 == LOW && Sensor1 == LOW)
    // backward
    digitalWrite(IN2, HIGH);
    digitalWrite(IN4, HIGH);
    //FORWARD
else {
  else  {
AWOL
Well, many people believe all sorts of weird stuff, so you're not alone.
Just don't do it here.
