school work
i have to make a train thingy for school but the break from case 1 to --- case 2 doesnt work anybody knows how does this come?
# include <Servo.h>
Servo servo1;
Servo servo2;
int angle=10;
int pos0=0;
int pos1=180;
int moment;
int ledpingroen1=2;
int ledpinrood1=3;
int ledpingroen2=4;
int ledpinrood2=9;
int piezopin=10;
int brightness=0;
int fadeAmount=5;
byte sensorpin1=A1;
int waarde1;
byte sensorpin2=A2;
int waarde2;
  pinMode(ledpingroen1,OUTPUT);
  pinMode(ledpinrood1,OUTPUT);
  pinMode(ledpingroen2,OUTPUT);
  pinMode(ledpinrood2,OUTPUT);
  servo1.attach(5);
  servo2.attach(6);
  servo1.write(180);
  servo2.write(90);
  waarde1=analogRead(sensorpin1);
  waarde2=analogRead(sensorpin2);
  switch(moment){
  case 0: // de normale stand geen treinen
  digitalWrite(ledpinrood1,LOW);
  digitalWrite(ledpinrood2,LOW);
  digitalWrite(ledpingroen1,HIGH);
  digitalWrite(ledpingroen2,HIGH);
  digitalWrite(ledpingroen1,LOW);
  digitalWrite(ledpingroen2,LOW);
  delay(400);
   if (waarde1<=100 || waarde2<=100){
    moment=1;
  break;    // naar 2de moment gaan
   case 1: // er is trein gezien rode lampen en slagboom en tutter
    digitalWrite(ledpinrood1,HIGH);
    digitalWrite(ledpinrood2,HIGH);
    for(angle = 40; angle < 155; angle++) {
    servo1.write(angle);
    servo2.write(angle);
    delay(15);
    tone(10,1000);
   delay(50);
   noTone(10);
   delay(50); }
   if (waarde1>=850 || waarde2>=850){
   moment=2;
  case 2: // slagbomen terug open en veilig
    for(angle = 160; angle < 40; angle--)  {
    delay(15);
How about adding some debug prints?
delay(50); } Don't do that.
Please remember to use code tags when posting code
If You check "How to use this Forum" You will discouver that Code Tags ought to be used for attached code. Then a lot more members can read the code and contribute.
To me it looks like
   moment=2;
should be investigated. What value do waarde 1 and waarde2 have here? Use Serial.print for debugging.
thx alot guys sorry i am really new with programming i hope i will become better
Everybode is new in using Forum and new in coding in the beginning…. I also made beginners mistakes in my first postings.
i am new with programming first project i have a problem that case 1 doesnt go to case 2 i hope you guys can help me thx
# include <Servo.h>
Servo servo1;
Servo servo2;
int angle=10;
int pos0=0;
int pos1=180;
int moment;
int ledpingroen1=2;
int ledpinrood1=3;
int ledpingroen2=4;
int ledpinrood2=9;
int piezopin=10;
int brightness=0;
int fadeAmount=5;
byte sensorpin1=A1;
int waarde1;
byte sensorpin2=A2;
int waarde2;
  servo1.attach(5);
  servo2.attach(6);
  servo1.write(180);
  servo2.write(90);
  switch(moment){
  delay(400);
    moment=1;
    delay(15);
    tone(10,1000);
   delay(50);
   noTone(10);
   delay(50); }
   moment=2;
    delay(15);
trein_spoor_3.ino (1.96 KB)
Don't cross post, sending the same question a second time using a new title. That makes many members really irritated.
    delay(15);
Check your placement if }
A L W A Y S format your code with OR
Do you happen to be in the same class as this fellow? :roll_eyes:
Threads merged.
viktordries:
Case 1 does not go to case 2 because of the break. To run case 2 you will have to satisfy switch( 2 ).
You can take the break out or put the code in case 2 into case 1. Whatever is logical.
