Topic: TM1914 ic rgb (Read 917 times) previous topic - next topic
Bartleboom
I'm trying to drive some rgb lights that have TM1914 inside. It's a 800Khz signal similar to WS2811 but it is inverted. Anyway, I got it works for a while but the lights immediately switch off.
I attached the original datasheet (in Chinese) and the translation.
Any suggestions?
PaulRB
Any suggestions?
Maybe you could explain the problem without contradicting yourself.
Also post your code and schematic.
Bartleboom
#2
May 24, 2019, 02:53 pm Last Edit: May 24, 2019, 02:57 pm by Bartleboom
Any suggestions?
Hi Paul, I mean that the ic recognize the color I choose (Red is 0xFF, 0x00, 0x00) but after a while it switch off.
The code is as follow:
Code: [Select]
int8_t pin = 6;
volatile uint8_t *port;
uint8_t pinMask;
uint8_t  hi, lo;
  pinMode(pin, OUTPUT);
  digitalWrite(pin, HIGH);
  port    = portOutputRegister(digitalPinToPort(pin));
  pinMask = digitalPinToBitMask(pin);
  hi   = *port |  pinMask;
  lo   = *port & ~pinMask;
  show();
  while (1) {}
the function show() send each bit as follow:
Code: [Select]
void show5(void) {
asm volatile(
    // This is bit 1
    "st %a[port], %[lo]"       "\n\t" // 2    PORT = low     (T =  2)
    "nop"                      "\n\t" // 1                   (T =  3)
    "nop"                      "\n\t" // 1                   (T =  4)
    "nop"                      "\n\t" // 1                   (T =  5)
    "nop"                      "\n\t" // 1                   (T =  6)
    "nop"                      "\n\t" // 1                   (T =  7)
    "nop"                      "\n\t" // 1                   (T =  8)
    "nop"                      "\n\t" // 1                   (T =  9)
    "nop"                      "\n\t" // 1                   (T =  10)
    "nop"                      "\n\t" // 1                   (T =  11)
    "nop"                      "\n\t" // 1                   (T =  12)
    "st %a[port], %[hi]"       "\n\t" // 2    PORT = hi      (T =  14)
    "nop"                      "\n\t" // 1                   (T =  15)
    "nop"                      "\n\t" // 1                   (T =  16)
    "nop"                      "\n\t" // 1                   (T =  17)
    "nop"                      "\n\t" // 1                   (T =  18)
    "nop"                      "\n\t" // 1                   (T =  19)
    "nop"                      "\n\t" // 1                   (T =  20)
// this is bit 0
    "st %a[port], %[hi]"       "\n\t" // 2    PORT = hi      (T =  8)
    "nop"                      "\n\t" // 1                   (T =  13)
    "nop"                      "\n\t" // 1                   (T =  14)
        : [port]  "+e" (port)
        : [hi]     "r" (hi),
          [lo]     "r" (lo));
Keeping in mind that Atmega328p is configured with 16.000.000 clk per second
For 800Khz signal each bit is 1.250 ns (20 clk)
In my sketch I send 9 bytes:
0xFF 0xFF 0xFA 0x00 0x00 0x05 (as per Datasheet Setting Mode DIN Mode)
and then I send 1 pixel display data:
0xFF 0x00 0x00 (Red color)
Then I send the Reset signal which is the Pin High for at least 200uS
PaulRB
What are these lines supposed to do?
Code: [Select]
This line of code
Code: [Select]
  while (1) {}
will stop the code from doing anything until you press reset. So if something happens after some time, it is not because of the code. Something else must be happening.
How many LEDs are connected? How are you powering the circuit?
Bartleboom
Quote
Code: [Select]
These lines save the value of PORTx register when is HIGH or LOW
this value is passed as argument in the assembly instruction ST
(turn on and off the pin)
Quote
This line of code
Code: [Select]
 while (1) {}
before the "while" we have one call to show() function which should light on 1 pixel
if I remove the while the lights are always on because it sends always the data to IC
Quote
I have two LEDs connected powered with 24V (ground is in common with arduino GND)
dgrandja
#5
Aug 05, 2020, 05:21 pm Last Edit: Aug 05, 2020, 05:26 pm by dgrandja
Hi, did you get very far with this ?
I have the same chipset on me light strip and im trying to find a way to get it to work with any of the arduino supported ESP chipsets
Bare with me as I'm super new to Arduino, ESP and addressable strip lights, however will catch up quickly.
