Topic: Help!!! Can l298n motor driver take 5v instead of 12 volts (Read 1 time) previous topic - next topic
aarush1212
i am pretty beginner in this i am creating a robot for my school project(yea i am in school) so i would just like to know that can  l298n motor driver take 5v instead of 12 volts as i want to run 2 5v motors and i think i may have to remove that voltage regulator jumper and supply 5v from arduino that's my guess if it can take 5v
slipstick
You can't safely run motors from the Arduino 5V pin. The L298N motor driver needs a separate supply.
It doesn't have to be 12V but since you are likely to lose around 2-3V in the chip to be sure of getting 5V to the motors you need to supply more than that to the motor driver. 4 or 5 AA batteries is about the minimum practical. Don't try using a little rectangular 9V battery because they can't provide enough current to run motors successfully.
Steve
jremington
Consider replacing the ancient, weak and energy-wasting L298 motor driver with a modern, efficient one.
The unrighteous man findeth no place to lay his head.
Idahowalker
This might help you answer that question:
https://www.youtube.com/watch?v=_rSHqvjDksg
