Topic: Dead slow IDE (Read 828 times) previous topic - next topic
ROVguy
Hello all.
I'm having issues with speed of Arduino IDE.
PC: SurfacePro 3 and SurfacePro 6
Arduino IDE 1.0.6, 1.8.8, 1.9.0
I was using my SP3 win10 and upgrading the Arduino IDE as new versions came available stopping at 1.8.9. I didn't have any issues with the IDE. IDE would boot in about 5sec.
 I had to replace my SP3 so I got the latest SP6. When I installed Arduino IDE 1.8.9 the bootup takes about 55sec to start the IDE, opening a sketch takes about 50 sec, compiling and saving it also took 50 sec. I replaced the IDE with 1.9.0 and had very similar results. Dead slow. Disabling virus and threat protection had no visible change on speed. I finally replaced the IDE with 1.0.6 and I got my speed back. Bootup, saving and compiling that same program takes about 5 seconds.
Does anyone know how to rectify this?
Thanks
pert
Try creating a file named portable in the Arduino IDE installation folder and see if that has an effect. The presence portable folder will cause the Arduino IDE to run in portable mode and not rely on any external folders. If those external folders were on a network drive or onedrive or whatever, that might explain the slowness.
ROVguy
Everything is saved within C drive. No network, external or cloud folders. After creating a portable folder within the IDE installation folder on C drive the IDE doesn't boot at all. You see the IDE pops open for a moment and then disappears.
pert
You must have the Arduino IDE installed to the Program Files (x86) folder. Windows 10 is very restrictive of changes to that folder. When the Arduino IDE starts, it's trying to create a sketchbook folder under the portable folder but Windows blocks that folder creation, which causes the Arduino IDE startup to fail.
ROVguy
Pert, You are correct I did have it saved in x86. After reading your comment I uninstalled and reinstalled the IDE just inside C:. The results is still the same
pert
I'm sorry to hear it didn't result in any improvement. Well at least the negative result tells us that accessing external folders is not the cause of the slowness. Unfortunately I'm out of ideas. The antivirus and the external folders are the only two potential causes of slowness I could think of. Hopefully someone else here will have another idea.
DrAzzy
Does turning off bluetooth change anything? I recall on one occasion, under conditions I don't remember, there was some issue with some IDE (maybe Arduino, maybe something else) being insanely slow because it was trying to enumerate bluetooth serial ports, and wound up waiting through a bluetooth device search timeout or something.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
flounder
The correct place to create a working folder in Windows is NOT under the .exe directory, but in the AppData folder for the user.  This means that if you have two different people who can log into the computer, their Arduino working directories are separate.  Only amateurs create working directories under the .exe directory.
I built windows apps for over 25 years.  The problem is learning to not follow the mistakes of people who didn't know what they were doing when they did it, and adopt the methods that are guaranteed to work.
       joe
pert
...which is exactly what the Arduino IDE does normally. However, there are some use cases where this is not convenient or not possible. For those use cases, there is portable mode.
ballscrewbob
There are a few posts about slow IDE conditions.
There are also a few differing solutions worth investigating.
Some involve computers security in regards to antivirus and such and others involve JAVA versions.
Would suggest using the search option to find them and read up a little more.
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
ROVguy
Sorry, this actually did work! I did the change late and didn't add the portable folder. I finally had time to go through this again and noticed the missing folder. Once added things sped up.
Thanks
pert
Great news! Now you could stick with portable mode or you can investigate further to try to find out how you can resolve the slowness issue when in non-portable mode. It's up to you.
When you are in non-portable mode, the Arduino IDE is accessing two external folders:
Sketchbook: The location is set in File > Preferences > Sketchbook location. When in portable mode, the default location of the sketchbook is {Arduino IDE installation folder}/portable/sketchbook. When in non-portable mode, the default location of the sketchbook is something like C:\Users\{user name}\Documents\Arduino, but it might be different if you have OneDrive enabled.
Data folder: When you are in portable mode this is located at {Arduino IDE installation folder}/portable. When in non-portable mode it is located at C:\Users\{user name}\AppData\Local\Arduino15.
So the next step in the investigation would be to determine which of those two folders were the cause of the slow down. The way you can do this is:
  • Delete the portable folder
  • Start the Arduino IDE
  • File > Preferences
  • Note the folder shown after "Sketchbook location".
  • Click the "OK" button.
  • Close the Arduino IDE
  • Create the portable folder
  • Start the Arduino IDE.
  • Set "Sketchbook location to the location of the sketchbook when in non-portable mode.
  • Close the Arduino IDE.
After doing that, there will likely be two possible results: If the Arduino IDE is still fast then you know that the problem is with the location of the data folder when not in portable mode. If the Arduino IDE is slow then you know the problem is with the location of the sketchbook folder you set in File > Preferences > Sketchbook location.
ROVguy
Well Pert. I was working on a new problem and decided to reinstall Arduino. While reinstalling it I followed flounder suggestion of installing it under  AppData. There I didn't need portable and everything seems to work just fine.
So again thanks to everyone that helped!
