Topic: LED Strip, random pattern and color (Read 541 times) previous topic - next topic
Twiggernaut
So this is a two part question. I'm very new to coding and have been mostly copy pasting my functions with a very basic understanding of how they work.
Problem 1:
I would like to randomly select a pattern from a predefined list of patterns. I have been reading up on arrays but i'm not sure how to make it work for my functions.
Problem 2:
I would like each pattern to randomly select a color from a list of colors.
Essentially, I would want this to cycle through the random patterns with random predefined colors.
Here is the code without the actual pattern functions (Exceeds character limit)
#include "FastLED.h"
#define NUM_LEDS_A 37
#define NUM_LEDS 37
CRGB strip[NUM_LEDS_A];
#define PINA 6
#define BRIGHTNESS 30
  FastLED.addLeds<NEOPIXEL, PINA>(strip, NUM_LEDS_A);
  FastLED.setBrightness(BRIGHTNESS);
//list of function commands that cause a pattern
  TwinkleRandom(500, 10, false);
  Twinkle(255, 0, 0, 50, 50, false);
  NewKITT(255, 0, 0, 2, 10, 50);
  Strobe(255, 0, 0, 10, 50, 10);
  FadeInOut(255, 0, 0);//red
  CylonBounceLong(0, 0, 255, 4, 10, 100, 5); // blue
  MeteorRain(255,255,0,2, 64, true, 10);//yellow
  RunningLights(255,0,0,50); //RED
  colorWipe(0,255,0, 10);
  rainbowCycle(10);
  theaterChase(255,0,0,50);
Grumpy_Mike
#1
May 29, 2019, 04:58 am Last Edit: May 29, 2019, 05:01 am by Grumpy_Mike
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Once you have set a pattern going how long do you want to run it for?
Would this be a fixed number of cycles of that pattern or for a fixed amount of time. The first is easy the second not so.
If it is the second then you have to convert all your pattern code into a state machine structure, this is a step up in difficulty than the normal code you are just getting to grips with. The essence of this is described here:- http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
If just a fixed number of cycles then just choose one of those functions at random using the "switch / case" structure. Look it up in the 'reference' entry in the Arduino's software help menu.
Quote
Then you have to change the code in each of those animations to do that. The list of colours will be in an array and you use a random number for the index of that array.
AWOL
