Topic: how to input values through serial monitor.please help (Read 42 times) previous topic - next topic
christinawilson205
i have to put  values for desired value through a serial monitor .i'm using a dc motor which has a potentiometer feedback and a H-Bridge. The current value reads the values from the pot .
Code: [Select]
int enB = 5;
int pin1 = 7;
int pin2 = 6;
int pot=A0;
int CurrentValue;
int DesiredValue;
  pinMode(enB, OUTPUT);
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT);
  pinMode(pot,INPUT);
  while (! Serial);
  Serial.println("Enter values between 60 - 960");
  if (Serial.available()){
    int DesiredValue = Serial.read();
 CurrentValue = analogRead(A0);
 if (CurrentValue>DesiredValue)
  //right
  digitalWrite(pin1,HIGH);
  digitalWrite(pin2, LOW);
  analogWrite(enB, 100);
if(CurrentValue<DesiredValue)
  //left
digitalWrite(pin1, LOW);
  digitalWrite(pin2, HIGH);
  analogWrite(enB,100);
  if (DesiredValue < 10 && DesiredValue > -10)
  analogWrite(enB,0);
Robin2
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
There is a simple user-input example in Planning and Implementing a Program
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
