Topic: IT IS HERE! Use Arduino as a disk drive (Read 1 time) previous topic - next topic
adafruit
here's something you've never seen before? - an arduino board that shows up as a disk drive, so you can drag and drop files that are stored on SD or SPI Flash over the USB connection. makes transferring assets like audio files, fonts, images, gifs, datalogs, etc as well as configuration scripts SUPER EASY! install the SAMD 1.5.0 board support package with TinyUSB stack support and the the example code here:
https://github.com/adafruit/Adafruit_TinyUSB_Arduino
and video!
https://youtu.be/0bWba0PU4-g
works with: SAMD21 and SAMD51 boards (also nordic's NRF52840).
pert
Very cool. Thanks adafruit!
Just to be clear, you are referring to Adafruit SAMD Boards 1.5.0, which can be installed via Boards Manager following these instructions:
https://learn.adafruit.com/add-boards-arduino-v164/setup
and this functionality is currently only available for the Adafruit SAMD Boards.
Correct?
jimLee
#2
Jun 05, 2019, 07:52 am Last Edit: Jun 05, 2019, 07:53 am by jimLee
Wait a second.. I been wanting (dying for) this for a long time now! Not being very fluent in all the chip numbers etc. Would this work on a teensy?
-jim lee
PNW Ardiuno & Maker club
1012 9Th Street, Anacortes, WA 98221 (Around the back of building)
