Topic: communication with Pure Data and a relay (Read 1 time) previous topic - next topic
Mimit7
Hi! I'm new in Arduino's world and I have a lot of problems that I'd like you to help me.
The thing is, I'm working with 4 ultrasonic sensors and a relay. I need to send the numbers of the sensors to pure data to make some audio process. Now about the relay, I need it to be activated when the 4 sensors are giving numbers under 10, but just for 800milliseconds because I'm using 220v and the components may break.
I have tried with so many codes, but as I don't understand the logic of Arduino, I can't change anything without making the code fall.
A code that was almost useful is one that I got from this forum, I'll put it in this question if you want some guide to know what I'm looking for.
#include <Boards.h>
#include <Firmata.h>
#include <FirmataConstants.h>
#include <FirmataDefines.h>
#include <FirmataMarshaller.h>
#include <FirmataParser.h>
#include <NewPing.h>       // https://bitbucket.org/teckel12/arduino-new-ping/downloads
#define SONAR_NUM       2   // Number or sensors.
#define PING_INTERVAL  33   // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
#define TRIGGER_PIN1    1   // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define TRIGGER_PIN2    3   // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN1       2   // Arduino pin tied to echo pin on the ultrasonic sensor.
#define ECHO_PIN2       4   // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE  300   // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
#define RELE            9   // Salida para el relevador
unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
unsigned long tstart;
unsigned int cm[SONAR_NUM];         // Where the ping distances are stored.
unsigned int Menor;
uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
bool Verifico5S = false;
bool activoRele = false;
NewPing sonar[SONAR_NUM] = {     // Sensor object array.
  NewPing(TRIGGER_PIN1, ECHO_PIN1, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(TRIGGER_PIN2, ECHO_PIN2, MAX_DISTANCE),
  Serial.begin(9600); // Open serial monitor at 115200 baud to see ping results.
  pingTimer[0] = millis() + 75;           // First ping starts at 75ms, gives time for the Arduino to chill before starting.
  for (uint8_t i = 1; i < SONAR_NUM; i++) // Set the starting time for each sensor.
    pingTimer = pingTimer[i - 1] + PING_INTERVAL;
/* 1. Cuando estén midiendo la distancia y la distancia medida en alguno de los 2 sensores sea menor a 10 cm
   durante un tiempo de 5 segundos, poner en alto la señal del relevador y
   2. Si la distancia en alguno de los 2 es mayor a 10 poner en bajo la señal,
  for (uint8_t i = 0; i < SONAR_NUM; i++) {       // Loop through all the sensors.
    if (millis() >= pingTimer) {               // Is it this sensor's time to ping?
      pingTimer += PING_INTERVAL * SONAR_NUM;      // Set next time this sensor will be pinged.
      if (i == 0 && currentSensor == SONAR_NUM - 1)
         oneSensorCycle();                // Sensor ping cycle complete, do something with the results.
      sonar[currentSensor].timer_stop();              // Make sure previous timer is canceled before starting a new ping (insurance).
      currentSensor = i;                              // Sensor being accessed.
      cm[currentSensor] = 0;                          // Make distance zero in case there's no ping echo for this sensor.
      sonar[currentSensor].ping_timer(echoCheck);     // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
  if (Menor < 10 && !Verifico5S) {                    // debo iniciar timer por 5 seg
     Verifico5S = true;
     tstart = millis()+ 5000UL;
  if (Menor > 10) {
     activoRele = false;
     Verifico5S = false;
  if (Verifico5S)                   // si estamos a menos de 10 cm verificar 5 segundos
     if (millis() >= tstart) {              // pasaron 5 seg?
      activoRele = true;
  if (activoRele)
      digitalWrite(RELE, HIGH);
      digitalWrite(RELE, LOW);
void echoCheck() { // If ping received, set the sensor distance to array.
  if (sonar[currentSensor].check_timer())
    cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
      if (i == 0)
       Menor = cm[0];     // fijo a Menor con el primer dato;
      if (cm < Menor)
         Menor = cm;   // Me quedo con el menor;
    Serial.print(i);
    Serial.print("=");
    Serial.print(cm);
    Serial.print("cm ");
PaulS
Why are you #including all the Firmata libraries?
Why did you fail to read the stickies, and post your code PROPERLY? Your code isn't in italics, is it?
