Topic: Bipass diodes for solar (Read 337 times) previous topic - next topic
tjones9163
Jun 02, 2019, 10:52 pm Last Edit: Jun 02, 2019, 10:53 pm by tjones9163
Hello, below is a circuit of a solar setup with bypass and blocking diodes.
I understand that the blocking diodes in the circuit are good to have because lets say that i have the panels hooked up to a battery when there is no light on the panels, the battery wont discharge through the panels.
I am trying to understand how the bypass diodes work, i get that it is good if lets say a shadow is covering part of the panel, you want to give a path for current to be able to flow without lots of resistance.
I found a pictorial diagram that i found below.
My question was, is it correct the way i drew the battery load and conventional current path in (red)?
MarkT
#1
Jun 03, 2019, 11:56 am Last Edit: Jun 03, 2019, 11:57 am by MarkT
The bypass diodes prevent the panels that are in shade from burning up - without them they could undergo reverse diode breakdown and overheat.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
tjones9163
thanks, is my conventional current direction correct?
MarkT
