Topic: Motor Carrier + Servo Motor Problems (Read 1 time) previous topic - next topic
gnatjian
Recently I tried the servo motor in the kit and I tried the sketch below.
I am pretty sure that I have updated the firmware and the servo is in the correct position.(By the way I tried each potion in the carrier.)
After I uploaded the sketch, the servo motor does not rotate at all although I can see the position of the servo on the serial port window from 0 to 180.
Any troubleshooting ideas? Thanks for any suggestions.
Code: [Select]
#include <MKRMotorCarrier.h>
#define INTERRUPT_PIN 6
//Variable to store the battery voltage
int batteryVoltage;
  //Serial port initialization
  while (!Serial);
  //Establishing the communication with the motor shield
  if (controller.begin())
      Serial.print("MKR Motor Shield connected, firmware version ");
      Serial.println(controller.getFWVersion());
      Serial.println("Couldn't connect! Is the red led blinking? You may need to update the firmware with FWUpdater sketch");
      while (1);
  // Reboot the motor controller; brings every value back to default
  Serial.println("reboot");
  controller.reboot();
  //Take the battery status
  float batteryVoltage = (float)battery.getConverted();
  Serial.print("Battery voltage: ");
  Serial.print(batteryVoltage);
  Serial.print("V, Raw ");
  Serial.println(battery.getRaw());
  //Reset to the default values if the battery level is lower than 11V
  if (batteryVoltage < 11)
    Serial.println(" ");
    Serial.println("WARNING: LOW BATTERY");
    Serial.println("ALL SYSTEMS DOWN");
    while (batteryVoltage < 11) {
    //Servo sweep from 0 position to 180
    for (int i=0; i<180; i+=5)
      //Choose what of all the servo connectors do you want to use: servo1(default), servo2, servo3 or servo4
      servo1.setAngle(i);
      Serial.print("Servo position");
      Serial.println(i);
      delay(50);
    delay(200);
    //Servo sweep from 180 position to 0
    for (int i=180; i>0; i-=5)
      servo1.setAngle(i);
      Serial.println(i);
      delay(50);
  //Keep active the communication MKR1000 & MKRMotorCarrier
  //Ping the samd11
  controller.ping();
  //wait
  delay(50);
gnatjian
The sketch went through well so there is no error information shown.
