Topic: Steppermotor only junps forwards and backwards (Read 393 times) previous topic - next topic
schwabenbraeu
Hello fellow CNC Friends,
i bought last year a T8 CNC  and used it for a while. Then I left in on the shell and wanted to use it again.
So i flashed the Arduino with new GRBL Version.
The catch is: X and Y only jump but Z-achsis works fine. Therefore i tried the steppermotor from Z on all the other components and it moves nomrally.
Now as I didn't change the cables and anything. How is it possible that the X and Y motor wont do their job after a year?
I tried
-new arduino
-new stepper controller board
-checking the cables
Hopefully you can help me.
StepperMotors Type: 17HA6403-08N
zwieblum
Your settings changed. Happend when flashing ...
schwabenbraeu
But how is it possible when i plug the motor from the z axis it moves but the same motor from X axis doenst?
wildbill
What happens if you put the X or Y steppers on the Z connections?
Can you use the stepper examples in the IDE to test the steppers individually?
Is there machine specific config that you set up originally that's been overwritten by the latest firmware?
schwabenbraeu
The same thing happens as would i have used the x or y ports. They rumble and nothing
As i use the Universal Gcode Platform, i can test tem individually.
The only configs i usually would have to make would be the steps per turn on the axis. But i already did this config. As i said Z-Achsis is fine.
schwabenbraeu
Found it, the cables where bad, and they didnt send the signal correctly. How this happens idk.
Thank you all :)
Robin2
Next time check that it works BEFORE you update the software :)
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
schwabenbraeu
...R
The only reason I flashed it was, that i could not establish a connection with it in the first place.
