Topic: Error in Compilation (Read 151 times) previous topic - next topic
santam
I'm using an arduino nano and everytime i try to compile the code, it shows the following. I've tried the option sketch>>Include Library>>Manage Libraries and have update the libraries but this keeps on showing.
Code: [Select]
Arduino: 1.6.7 (Windows 10), Board: "Arduino Nano, ATmega328"
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareSerial is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Wire is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'Arduino AVR Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
D:\Program Files\Arduino\hardware\tools\avr/bin/avr-ar: unable to rename 'core\core.a'; reason: Permission denied
exit status 1
Error compiling.
  enabled in File > Preferences.
pert
Code: [Select]
Unrelated to your problem, but is there a reason why you're using such an old version of the Arduino IDE? 1.6.7 wasn't a particularly good IDE version.
Code: [Select]
Still likely unrelated to your problem, but this indicates you're using a version of Arduino AVR Boards that's even more outdated than your IDE version!
Code: [Select]
Now for the real problem. This sort of error could be caused by your antivirus software. Try TEMPORARILY disabling your antivirus for a single compilation to see if the problem goes away, then turn the antivirus back on. If the problem doesn't occur with the antivirus off you will need to adjust the settings of your antivirus to whitelist the appropriate file, folder, or process so it doesn't interfere with compilation.
santam
 I've also used the latest version but that might have caused some compatibility issues with the board.
pert
Latest version of the Arduino IDE, or latest version of Arduino AVR Boards?
santam
Latest version of Arduino IDE. Can you tell me how can i upgrade the arduino avr board?
pert
  • Tools > Board > Boards Manager
  • Wait for the downloads to finish.
  • Click on "Arduino AVR Boards by Arduino".
  • Click the "Update" button.
  • Wait for the update to finish.
  • Click the "Close" button.
The above instructions will update to the latest version of Arduino AVR Boards. If you instead want to update to the version of Arduino AVR Boards that Arduino IDE 1.6.7 came with (which is newer than the version of Arduino AVR Boards you are currently using) then instead of clicking the "Update" button, select "1.6.9" (yes, the Arduino AVR Boards versions and IDE versions don't match) from the dropdown menu and click the "Install" button.
santam
okay,I've updated the IDE to 1.8.9 and update the avr board to 1.6.23. Now while uploading the code I'm getting this error.
Code: [Select]
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 724 bytes (2%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_recv(): read error: Access is denied.
avrdude: ser_send(): write error: sorry no info avail
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
the selected serial port avrdude: stk500_recv(): programmer is not responding
 does not exist or your board is not connected
option enabled in File -> Preferences.
pert
This is progress!
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
If you don't know which port is your Arduino, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
Make sure no other application has the port of your Nano open. A COM port may only be open in one application at a time.
If none of that helps, try restarting your computer. Sometimes a glitch can cause COM ports to get stuck in an unusable state and restarting fixes this.
santam
#8
Jun 10, 2019, 12:55 pm Last Edit: Jun 10, 2019, 12:57 pm by santam
I've used another port but still it did not work. I restarted the computer as well.
Code: [Select]
avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
pert
santam has created a new thread about the upload error:
https://forum.arduino.cc/index.php?topic=620604
