Topic: Hc-05 bluetooth module connection with L293d motor shiled with Arduino Uno  (Read 456 times) previous topic - next topic
Raktim2000
I want use L293d Motor shield with Arduino Uno and also want to connect a Hc-05 Bluetooth module with Arduino Uno Pin 0 and 1. But, L293d motor shield already take 0 and 1 PIN. Then, how I connect the Bluetooth module?
link for zoom view of the shield...
https://www.resistorpark.com/arduino-motor-shield-l293d/
Grumpy_Mike
Quote
By using software serial.
Raktim2000
I watched some video where they solder 2 jumper wire with the top of the l293d motor shield or bottom of the arduino board to connect 0 and 1 pin the Bluetooth. Is it possible to work ? And l293d motor shield takes all Arduino Uno's digital pins (except pin 2). So, how i use the   "software serial" ?
Grumpy_Mike
Quote
Use the analog pins as digital I/O.
Wawa
No it doesn't. Shields always cover all pins, but not all pins are actually used.
But you shouldn't use pin 0,1 anyway.
Because pin 0,1 are already used by the USB<>Serial chip.
As Grumpy_Mike said, use SoftwareSerial on the analogue pins.
You can add a pinstrip to the shield holes marked A0-5 for easier connection with Dupond wires.
SoftwareSerial examples can be found in File>Examples of the IDE.
Leo..
Raktim2000
Thank you Grumpy_Mike for helpe me...
Leo..
Thanks wawa...
Raktim2000
Grumpy_Mike suggest me to use SoftwareSerial  and analog pin to use as digital pin. It's ok and one this is the another way.
But, if I  placed the motor shield to Arduino uno. Just like this
Then, can I solder some wire with the motor shield's  0 and 1 pin for serial communication ? Is It works?
Grumpy_Mike
Quote
Only because in the original post you said:-
Quote
If this statement is not true, as it now appears not to be, then yes you can use those pins if you can get at them to make connections to them.
Raktim2000
Thank you
