Topic: slow lighting or dimming (Read 489 times) previous topic - next topic
artuksa
Hello there, have started with a very simple for loop to brighten/or dim an led lamp.
// Dim an LED using PWM
int PWMpin = 10;
  for (int i = 0; i <= 255; i=i++)
    analogWrite(PWMpin, i);
    delay(5000);
Can anyone suggest the approach I could take to make a very slow dim/brighten loop up to 60 minutes or longer, or is a 'slow loop' not a good approach to this, would appreciate some suggestions as to how I might approach this, thanks.
Grumpy_Mike
Just change the delay to make the process longer.
To make that code last an hour then the delay should be for:-
(60 * 60) / 256 seconds
PaulRB
It depends what else you need your Arduino to do at the same time. If it needs to react to events like button presses during lighting/dimming, then this slow loop is not suitable. But if the Arduino has nothing else to do, then its OK.
artuksa
Thanks for the replies, appreciated
