Topic: speeding up Arduino start up time?? (Read 2193 times) previous topic - next topic
federicomuelas
hi everyone,
I'm using the arduino mini on a battery operated project that has to last at least four months. I'm using a Latch relay to fully cut the power to the arduino when no need it. if I use the sleep or power off function of the arduino still is using a bit of current that will eventually drain the battery.
the system works fine but when turned on I need the arduino to response as fas as possible. I haven't tried with the Arduino Mini yet, but i tried with the mega and a 9 v battery and it takes at least a second to start executing the code. is there a way to speed up the start up time of the mini?
thanks!!!
F
spycatcher2k
if its a permanent install, buy a blank chip, and burn the sketch to it with a programmer - no boot loader = no pause at start-up.
Drew
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
federicomuelas
oh, thanks Drew,
now that you told me I found this link
http://www.arduino.cc/en/Hacking/Programmer
thanks!
F
