Topic: Circuit Symbol (Read 454 times) previous topic - next topic
DucksandCo
Jun 14, 2019, 12:37 am Last Edit: Jun 14, 2019, 01:01 am by DucksandCo
Hello all,
I am currently making a sprinkler system that waters its plants when the soil is dry enough. My teacher has drew in this diagram regarding how I should hook up my transistor. I dont really know what symbol this really is.
http://Resistor https://imgur.com/gallery/qd8FBSI
This is the actual arduino setup.
http://Ard
https://imgur.com/gallery/YCkygPm
Thank you.
dl324
#1
Jun 14, 2019, 12:56 am Last Edit: Jun 14, 2019, 01:10 am by dl324
I've found posting pictures on this forum to be somewhat cumbersome.  I see what appears to be two images, but nothing is visible.
EDIT: fiddling with images...
No clue what your teacher is referring to.  We need to know the part number because there are three different pinouts for TO-92 transistors (2N, BC, and 2S).  Since one pin in grounded, I'm guessing it's an NPN transistor with the emitter grounded.
Southpark
#2
Jun 14, 2019, 02:05 am Last Edit: Jun 14, 2019, 02:07 am by Southpark
Adequate information is required in order to make sense of a circuit diagram. In this case --- not enough information. Device details (eg. transistor model etc) is needed. Also - intended purpose --- ie. what is required for it to do --- should be understood in advance as well.
In this case, there's not enough details. More details are required.
larryd
Boy oh boy, looks like - GND to Emitter, + to maybe a solenoid then maybe the Collector, Dout from an Arduino to the Base.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
dl324
#4
Jun 14, 2019, 03:37 am Last Edit: Jun 14, 2019, 03:40 am by dl324 Reason: Jumping through hoops to add images.
After looking at your second picture, I could see that you're using a transistor in TO-220.
This is the pinout:
Your teacher should have drawn the schematic this way:
Southpark
#5
Jun 14, 2019, 07:18 am Last Edit: Jun 14, 2019, 07:18 am by Southpark
Could it be a logic level mosfet too?
larryd
Forgot to include a kickback diode.
No technical PMs.
Paul__B
Oh dear, pictures (clickable)!
dl324
If your response was regarding my post, I redrew what the teacher drew, not what it should have been.
dl324
The resistor on the lead marked Dout wouldn't be necessary and a resistor from gate to source would have been included so the gate wouldn't float when the GPIO port wasn't active.
larryd
No, I was looking at the teachers image.
No technical PMs.
Southpark
#11
Jun 14, 2019, 11:43 pm Last Edit: Jun 15, 2019, 12:03 am by Southpark
This is all based on assumptions, which is why it can be a time-wasting exercise if there's inadequate details to begin with.
Additionally, if you assume a BJT, then the input could become floating under those conditions you mentioned too maybe, right?
Also ----- using series resistor for gates of mosfets is not uncommon.
It may well be a BJT. And all I'm saying is - if there's not enough information to start with - then it's like a goose chase.
Southpark
#12
Jun 15, 2019, 11:10 am Last Edit: Jun 15, 2019, 12:03 pm by Southpark
Make sure your breadboard connections are correct too. Example..... hole j1 has an orange wire..... but the purpose of it is unclear. Same for hole c1.
