Topic: Ethernet W5100 randomly unresponsive as web server (Read 246 times) previous topic - next topic
mososki
I have a program that uses an ultrasonic sensor to measure the water height at my dock on Lake St. Clair and post it on a simple web page.  I used the example programming to do the server parts and it works fine until I get no response after a random time; a day or two.  I don't understand a lot of the programming but it works until it doesn't and then I have to go out and reset it.  I added a 12 hour reset circuit to see if I could prevent the problem, but it still locks up.  The unit is powered by a 6 or 12 volt wall wort and has worked thru winter and summer.  Am I missing something?
Wawa
What does that mean.
6volt (regulated) on V-in is borderline low, but is too low for the DC socket of the (assuming) Uno.
12volt on the DC socket or V-in is definately too high with a W5100 shield on top.
The Uno's 5volt regulator will randomly overheat and reset from the extra ~160mA current draw of the ethernet shield.
We... are missing most of it, including the attached code which we can't see or won't open.
Read the "How to post" sticky.
Leo..
