Topic: ESP32 and GPS Neo-6m, problem on reading data  (Read 2100 times) previous topic - next topic
GuilhermeVolker
HI!
I'am trying to read data from the Neo-6m GPS on ESP32, using arduino IDE. But all i got now its a baunch of zeros, is there some exemple out there for me to understand why i have this problem? Thanks in advance.
Code: [Select]
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial serial1(3, 1); //rx,tx
  serial1.begin(9600); //gps baud
 bool recebido = false;
  while (serial1.available()) {
     char cIn = serial1.read();
     recebido = gps.encode(cIn);
Serial.print(gps.date.value());
Serial.print(" | ");
Serial.print(gps.altitude.feet());
Serial.println(gps.satellites.value());
Idahowalker
Why use Software Serial with an ESP32?
Whiles I am using an AdaFruit Ultimate GPS the principle is the same.
I load up the #include <TinyGPS++.h> library.
I load #include <HardwareSerial.h>
I declare a TinyGPSPlus GPS; and HardwareSerial GPSSerial ( 1 );
In setup I do these things
Code: [Select]
GPSSerial.begin ( GPS_DataBits, SERIAL_8N1, 2, 15 ); // begin GPS hardware serial
xTaskCreatePinnedToCore( fGPS_Parse, "fGPS_Parse", TaskStack10K3, NULL, Priority5, NULL, TaskCore0 ); // assigned to core 0
  sema_GPS_Gate = xSemaphoreCreateMutex();
  xSemaphoreGive( sema_GPS_Gate );
This is the defined task to get the GPS data:
Code: [Select]
void fGPS_Parse(  void *pvParameters )
  int iBit = 1;
  for (;;)
    xEventGroupWaitBits (eg, evtGPS_Parse, pdTRUE, pdTRUE, portMAX_DELAY) ;
    if ( xSemaphoreTake( sema_GPS_Gate, xTicksToWait0 ) == pdTRUE )
      //query GPS: has a new complete chunk of data been received?
      if ( GPSSerial.available() > 1 )
        if ( GPS.encode(GPSSerial.read()) )
          if (  GPS.location.isValid())
            if ( xSemaphoreTake( sema_Posit, xSemaphoreTicksToWait ) == pdTRUE )
              xPosit.Lat = GPS.location.lat();// store data into structure
              xPosit.Lon = GPS.location.lng();
              xSemaphoreGive( sema_Posit );
          } // if (  GPS.location.isValid())
          if (GPS.speed.isValid())
              xPosit.MPH = GPS.speed.mph();
              xPosit.KPH = GPS.speed.kmph();
          } //  if (GPS.speed.isValid())
          if (GPS.time.isValid())
            if ( xSemaphoreTake( sema_Time, xSemaphoreTicksToWait ) == pdTRUE )
              xTime.iSeconds = GPS.time.second();
              xTime.iMinutes = GPS.time.minute();
              xTime.iHours = GPS.time.hour();
              xSemaphoreGive( sema_Time );
          } // if (GPS.time.isValid())
          if (GPS.date.isValid())
            if ( xSemaphoreTake( sema_Date, xSemaphoreTicksToWait ) == pdTRUE )
              xDate.iMonth = GPS.date. month();
              xDate.iDay = GPS.date.day();
              xDate.iYear = GPS.date.year();
              xSemaphoreGive( sema_Date );
          } // if (GPS.date.isValid())
          if (  GPS.altitude.isValid() )
              xPosit.Alti = GPS.altitude.meters();
          } //  if (  GPS.altitude.isValid() )
          if ( GPS.course.isUpdated() )
              xPosit.Hdg = GPS.course.deg();
          } // if ( GPS.course.isUpdated() )
            xQueueOverwrite( xQ_Posit, (void *) &xPosit );
        } // if ( GPS.encode(GPSSerial.read()))
      } // if ( GPSSerial.available() > 0 )
  } // for (;;)
  vTaskDelete( NULL );
} // void fGPS_Parse(  void *pvParameters )
GPS Parsing is triggered by a 1mS hardware timer. Works great.
1/18/2018, got my first Arduino Uno.
GuilhermeVolker
I just bought one esp32, so i'am still learning. I'll try your code, thanks a lot!
srnet
#3
Jun 14, 2019, 10:04 pm Last Edit: Jun 14, 2019, 10:05 pm by srnet
Have you realised that every time a character arives from the GPS, you go off and print to the serial console a whole lot of information that has almost certainly not been updated ?
You should keep sending stuff to the gps.encode function until a fix is updated, then you can print the lat and long stuff to the serial monitor.
No PMs please, they dont get answered.
srnet
This is what I would do;
Code: [Select]
  if (gps.location.isUpdated() && gps.altitude.isUpdated())
GuilhermeVolker
Now, with all the modifications on the code:
Code: [Select]
//#include <SoftwareSerial.h>
TinyGPSPlus gps;
//HardwareSerial Serial1(3, 1); //rx,tx
 Serial1.begin(9600, SERIAL_8N1, 3, 1); //gps baud
  while (Serial1.available()) {
     char cIn = Serial1.read();
On the Serial port i'am receiving this mensage, without any data from the gps  :smiley-eek: :
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1100
load:0x40078000,len:9232
load:0x40080400,len:6412
entry 0x400806a8
Idahowalker
Code: [Select]
The ESP32 does NOT have a Serial0 or Serial1 or Serial2. The ESP32, for serial ports has (0), (1), (2).
What you are seeing on Serial is normal boot stuff.
GuilhermeVolker
#7
Jun 15, 2019, 05:48 pm Last Edit: Jun 15, 2019, 05:49 pm by GuilhermeVolker
Well, i finally was able to read the gps data, the code that  made it possible is bellow:
Code: [Select]
/*some obs:
 *  * There are three serial ports on the ESP known as U0UXD, U1UXD and U2UXD.
 * U0UXD is used to communicate with the ESP32 for programming and during reset/boot.
 * U1UXD is unused and can be used for your projects. Some boards use this port for SPI Flash access though
 * U2UXD is unused and can be used for your projects.
 * on the code, i use the u2uxd. Dont forget to invert the rx/tx with the sensor ;)
#define RXD2 16
#define TXD2 17
TinyGPSPlus gps;
 Serial1.begin(9600, SERIAL_8N1, RXD2, TXD2); //gps baud
    Serial.print("D/M/A: ");
Serial.print(" | alt: ");
Serial.print(" | satellites: ");
