Topic: Log distance Signal (Read 675 times) previous topic - next topic
madguernseyboy
Jun 15, 2019, 07:26 pm Last Edit: Jun 15, 2019, 07:37 pm by madguernseyboy
If I have two Arduinos 50m apart and send a HIGH signal on one will it be received by the other even though it is so far away? Do i need a pull down resistor?
assume using 1mm house electric wire.
Thanks all.
Brendan
larryd
O/P to I/P requires no resistor.
You do know you will need a common ground return path between the two Arduinos?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
jremington
You need two wires, signal and ground. For low data rates, 50m is no problem.
madguernseyboy
Thank you
so no need for the resistor.
I have a common ground so thats no problem either.
thanks
Brendan
larryd
BTW, using an opto coupler can prevent ground loop problems.
A 6N137/138 is a good choice.
No technical PMs.
Wawa
#5
Jun 16, 2019, 08:49 am Last Edit: Jun 16, 2019, 08:50 am by Wawa
+1
There is the risk of phantom powering (if one is on and the other one is off).
I would use an opto coupler, as larryd suggested.
Use the opto at the receiving end (near input pin).
Opto emitter to ground, collector to pin, pull up enabled on input pin in setup().
 pinMode(optoPin, INPUT_PULLUP);
2-core wire from opto LED to other Arduino.
On the transmitter Arduino.
LED cathode wire there to ground, 1k resistor between output pin and LED anode wire.
Leo..
madguernseyboy
Hi all (thank you for the responses)
all arduinos would be powered from the same power supply so phantom powering shouldn't happen.
however just to ensure I got your description correct for others can you please check my schematic.
jremington
R1 may need to be lower, 220 Ohms or so. You will need INPUT_PULLUP or a 10K pullup resistor on D13.
larryd
If you use a 6N137 example:
No technical PMs.
MarkT
For that long a run an optocoupler is wise, to prevent spikes destroying either Arduino when there is nearby lightning or heavy mains switching transients.
Wawa
Then forget about the opto coupler, and use shielded wires or twisted pairs for data and power. Cat-5 is cheap.
I hope you don't have any interfering sources near.
Leo..
The whole idea of an opto coupler is to have no ground link between devices, to prevent ground loops and interference.
Cut the short ground link under the opto in the diagram.
You now must have two separate supplies. A 5volt phone charger connected to the USB socket could do.
Leo..
NoraTheDoggo
As long you don't use mains to power it, you can just shove a wire into the earth and connect it to the arduino ground. This will cause the arduinos to have a common ground without another wire.
I must ask you a question:
Have you considered a radio transmitter. You can get a sufficient pair for under 10 dollars.
I like cooking children and Arduinos
Is not the same as: I like cooking, children, and Arduinos
Grammar matters!
larryd
As long you don't use mains to power it, you can just shove a wire into the earth and connect it to the arduino ground. This will cause the arduinos to have a common ground without another wire."
OMG, but I live in the middle of the Sahara Desert :( .
No technical PMs.
NoraTheDoggo
You may be out of luck. The ground needs a little bit of moisture. Sorry.
Grammar matters!
