Topic: -Newbie /where to add a limit switch code to my existing sketch up (Read 598 times) previous topic - next topic
tinback123
 Hi
everyone
I'm using:
- Power source 12V 5A
-NEMA 23 stepper motor 200 steps/1.8°
-TB5860 Motor Driver
-Arduino UNO R3
The following code lets me, by pressing a button, to move my motor CW. I have another button that when i press it lets me move my motor CCW, and it will automatically move 300 steps. ( 540°)
I also have connected a limit switch, but that still requires to be programmed in order for it to work.
I found this tutorial online with its code  that shows that when a limit switch is pressed, the motor will stop.
I want to replicate that and put it on my code.
The thing is I do not know what to copy and modify exactly from that code and where to put it.
[This is the code im using ][/// defines pins numbers
const int dirPin  = 3;
const int stepPin = 2;
const int enPin   = 6;
const int limitPin = 7;
const int switchOne     = 8;
const int switchTwo     = 9;
int p1buttonState = 0;         // current state of the button
int lastp1buttonState = 0;     // previous state of the button
int p2buttonState = 0;         // current state of the button
int lastp2buttonState = 0;     // previous state of the button
bool bPress = false;
bool isForward = false;
bool isBackward = false;
  pinMode( switchOne, INPUT_PULLUP);
  pinMode( switchTwo, INPUT_PULLUP);
  pinMode(limitPin,INPUT);
  // Sets the two pins as Outputs
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  pinMode(enPin,OUTPUT);
  digitalWrite(enPin,LOW);
   isForward = false;
   isBackward = false;
   p1buttonState = digitalRead(switchOne);
   p2buttonState = digitalRead(switchTwo);
  if (p1ButtonPress()) {
    digitalWrite(dirPin,HIGH);
    delay(5);
    if (p2ButtonPress()) {
      digitalWrite(dirPin,LOW);
      delay(5);
    if( isForward || isBackward ){
      for(int x = 0; x < 300; x++) {
        digitalWrite(stepPin,HIGH);
        delayMicroseconds(1200);
        digitalWrite(stepPin,LOW);
bool p1ButtonPress()
   bool isPress = false;
   // compare the p1buttonState to its previous state
  if (p1buttonState != lastp1buttonState) {
    // if the state has changed, increment the counter
    if (p1buttonState == LOW) {
      // if the current state is HIGH then the button went from off to on:
      bPress = true;
      isPress = true;
      Serial.println("Plaer One score");
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
      isForward = true;
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastp1buttonState = p1buttonState;
  return isPress;
bool p2ButtonPress()
  if (p2buttonState != lastp2buttonState) {
    if (p2buttonState == LOW) {
      bPress = true;
      isPress = true;
      Serial.println("Plaer Two score");
      isBackward = true;
    delay(50);
  lastp2buttonState = p2buttonState;
  return isPress;
Regarding the limit switch, the red wire is connected to the arduino 5V
the black wire is connected to Arduino GND
The green/blue, which is the signal, is connected to pin7.
I tried copying
if( digitalRead(limitPin) == HIGH){
   delayMicroseconds(500);
and to put it in several places of my own code but i get an error message (img attached).
What's highlighted in yellow is what I copied from the other code. I do not know if it is correctly placed or not... or if I have to modify something on it... ( im still very new to  all this arduino mambo jambo)
Could anybody please provide me some help/guidance?
Thank you
vaj4088
How could you possibly expect help if you don't show the problematic code and don't show the error message?  It might be something simple but who can tell?
Looks like you might be missing a right curly bracket but who knows?
Romonaga
Sigh,
If this is the complete code, than the compile message should have been a big clue as to why it will not compile.  It would be helpful to see this error when posting.
In any event, p1ButtonPress and p2ButtonPress are not defined.
Not sure what there are to be used for.
tinback123
I just added as an attached file on the first post the problem itself.
"p1ButtonPress1 was not declared in this scope"
( i honestly don't know what to write there)
tinback123
Sigh,
Hi
you're right. sorry about that
Please have a look at the image I attached on the first post.
Whenever I copy and paste the lines highlihgted in yellow, I get the error. If not, the code works fine ( but without the limit switch, of course)
Romonaga
The compiler is screaming the issue. I have told you what is wrong.
The 2 variables are not defined.
vaj4088
p1ButtonPress() and p2ButtonPress() are functions.  Unfortunately, they are defined AFTER the place where they are used, and C/C++ requires that they be defined BEFORE they are used.  Typically, a .h file is included with function declarations so that this does not happen.
If you do not know how to make and include a .h file, just move the definitions of these functions to a place ahead of the loop() function, say, between the setup() function and the loop() function.
vaj4088
Of course, the Arduino IDE does some preprocessing to try to deal with this issue, but it can be fooled (although I am not seeing the problem with this code)  or you could have an issue if you use some IDE other than the Arduino IDE.
tinback123
If I put this code :
between the setup() function and the loop() function the code works, but not as intented.
Only by clicking the limit switch, and pressing a button, the motor will spin.
I really don't know how to keep going with this...
Any more advices/tips/suggestions are more than welcome
Gates
Tinback123,
I would suggest to you, stop poking at a solution... you need to step away from the code and sit down and make a UML of your program. You might only need an Activity diagram to help you understand why your code isn't progressing as you wish.
You might think that this isn't very helpful, but it is extremely important that you clearly understand why a problem may occur throughout your coding now and in the future. After you finish writing these diagram/s you will be more prepared to expand your program. I usually use names in my diagrams that are used in the development of the program.
I'll just add one thing to this post. As it was suggested in post#6 including spinets of code already written will make your programming experience much easier and generally more readable to you & others that might be involved with your projects.
msd1811
if your code run OK and you only need to add limit switch. don't let the piece of code that turn the motor execute:
Code: [Select]
if( (isForward || isBackward ) && digitalRead(limitPin) == HIGH){ // limit not pressed
or do it as you wish.
Gates
Wrong,
Only add a process, if previous data is invalid.
Do you need to start you car twice? You might need to see your mechanic.
You don't replace the engine, do you?
tinback123
im re doing this from sratch
and there are some things i do not know how to write them.
Here's my code with its coments and with my doubts:
// define the numer of pins
const int dirPin  = 3; //Direction Pin
const int stepPin = 2;  // Steps Pin
const int enPin   = 6;  //Enable Pin
const int limitPin1  =7; //LimitPin 1
const int limitPin2 =8; //LimitPin2
const int botonuno     = 8; //Buttono 1
const int botondos     = 5; //Button 2
  pinMode( botonuno, INPUT); //
  pinMode( botondos, INPUT); //
  pinMode (limitPin1,INPUT); //   I dont know if it should be INPUT or INPUT_PULLOUT? ( I can't understand what Pullout actually means in this code ( I've already seen examples of it)
  pinMode (limitPin2,INPUT); //  same here
  // Output pins
Here's when I get confused
if I press button 1 or button 2( once, not holding it pressed), it should do 300 steps.
The code should be something like this(or not....?):
now... if button 1 is pressed and the motor is rotating to CW, and it hits the limit switch, the motor should stop, it should not let it move CW again, and  it should allow button2 to be pressed and the motor to rotate CCW.
Same thing the other way around. So I have something like this:
 if (boton1 ==HIGH) { //If I press button1
      if (!digitalRead(limitPin1)) {} //check if LimitPin1 was pressed  (is this right?)
      else { // if limit switch wasnt activated, allow the motor to rotate
      delay(5);
Now, if this is correct, what's the order it should be put in the code?
if those coding lines are not correct, what do I need to change/add/ remove?
vaj4088
You asked "INPUT or INPUT_PULLOUT?"  Never INPUT_PULLOUT.  Perhaps you intended INPUT_PULLUP.  It is hard to go wrong with INPUT_PULLUP no matter what your wiring.  However, if you really want to choose between INPUT and INPUT_PULLUP, you need to share your wiring diagram or equivalent.  I cannot see your wiring and my crystal ball is in the shop!   :smiley-lol:
This
Code: [Select]
will probably work correctly, but according to the documentation at
https://www.arduino.cc/reference/en/language/functions/digital-io/digitalread/
it should be
Code: [Select]
  if (digitalRead(limitPin1) == LOW) {} //check if LimitPin1 was pressed.
although possibly LOW should be HIGH depending upon how the limit switches work and how they are wired.
tinback123
Hi!
I'm attaching my wiring diagram
I did not include on it any power supply, but in case you have any doubts.
The driver is connected to a 12V 5 A power supply ( the motor is a nema 23 stepper motor up to 3A)
and the arduino is connected via USB.
so inputs for the limit switch should be pins 4 and 7
I did a boo-boo before so my code should actually be this at start:
const int limitPin2 =4; //LimitPin2
const int botonuno     = 8; //Button 1
const int botondos     = 9; //Button 2
I hope this was helpfull for you
