Topic: customized function "led" can't be recognized (Read 208 times) previous topic - next topic
Tan_Yuanqing
Hi Here is my code. The error is "exit status 1:  'led' was not declared in this scope". For covenience, I have spread red color on the "led" code.
Code: [Select]
// Digital value of sensor
#define SENSORD 26
//int count = 0;
int KEY_NUM = 0;
//analog value of sensor
#define SENSORA A1
int val_AD = 0;
// LED
//DC motor with encoder
 #define outputA 24//interrupt pin
 #define outputB 22//input pin
 int counter = 0;
 int aState;
 int aLastState;
 int val = 50;//pressure speed->motor 1
 int delaytime = 20;
 int VAL = 50;//stress speed->motor 2
   pinMode(SENSORD,INPUT);//sensor digital value
   pinMode(SENSORA,INPUT);//sensor analog value
   pinMode(outputB,INPUT);//encoder signal 1
   pinMode(outputA,INPUT);
   pinMode(7,OUTPUT);//motor positive pole
   pinMode(8,OUTPUT);//motor negative pole
   pinMode(9,OUTPUT);//motor speed
   pinMode(10,OUTPUT);//motor positive pole
   pinMode(11,OUTPUT);//motor negative pole
   pinMode(12,OUTPUT);//motor speed
   pinMode(13,OUTPUT);//led pin
   Serial.begin (9600);   // Reads the initial state of the outputA
    digitalWrite(34,HIGH); //signal to make motor start rotate
   attachInterrupt(34, positionx, HIGH);
   attachInterrupt(26, [color=red]led[/color], HIGH);//thredhold
   attachInterrupt(26, motorBrake, HIGH);//forward brake
   attachInterrupt(32, motorreverse1, HIGH);//reverse begin
   attachInterrupt(30, motorBrake, HIGH);//reverse brake
    sensor();
   // Serial.print("Pulse:");
   // Serial.println(counter);
 //motor attacth
 void positionx(){
  for( int i=1; i<=5; i++ ) {
  aLastState = digitalRead(outputA);
  motorforward1();
    Serial.print("access positionx");///////////////////////
    aState = digitalRead(outputA); // Reads the "current" state of the outputA
   // If the previous and the current state of the outputA are different, that means a Pulse has occuredL
   Serial.println(aLastState);/////////////
          Serial.println(aState);
   if (aState != aLastState){
     // If the outputB state is different to the outputA state, that means the encoder is rotating clockwise
     int M=digitalRead(outputB);
       Serial.println(M);////////////////////
     if (M != aState) {
       counter ++;
       counter --;//rotation direction: after each pulse if outputA and B are the same, means rotate
     Serial.print("Position: ");////////
     Serial.println(counter);/////////
  delay(5000);
  motorreverse1();
//motor forward
   void motorforward1(){
   digitalWrite(7,LOW);
   digitalWrite(8,HIGH);
   int value1 = val+(val_AD/8);//P control of motor1 speed
   analogWrite(9,value1);
    delay(delaytime);
     void motorforward2(){
      digitalWrite(10,LOW);
    digitalWrite(11,HIGH);
    int value2 = VAL+(val_AD/8);
    analogWrite(12,value2);
    delay(delaytime);
     void motorreverse1(){
   digitalWrite(7,HIGH);
   digitalWrite(8,LOW);
   analogWrite(9,val);
    delay(delaytime);
     void motorreverse2(){
    digitalWrite(10,HIGH);
    digitalWrite(11,LOW);
    analogWrite(12,VAL);
    delay(delaytime);
  //motor stop
   void motorBrake()  {
   digitalWrite(7, LOW);
   digitalWrite(8, LOW);
    //Digital value of sensor
    void sensor()
    Serial.println("Digital value of sensor");
  if(digitalRead(SENSORD) == HIGH)
    delay(10);
      while(digitalRead(SENSORD) == HIGH);
         Serial.println("threhold of sensor");
      KEY_NUM = 1;
  if(KEY_NUM == 1)
    KEY_NUM = 0;
    Serial.println("press!");///////////////////////////////
    val_AD = 1023 - analogRead(SENSORA);//detect analog number can be used to P control.
  Serial.print("AD = ");////////////////////////////////////
  Serial.println(val_AD); //////////////////////////////
       // LED
   void [color=red]led[/color]()  {
   digitalWrite(13,HIGH);
   Serial.println("LED!");///////////////////////////////
   motorBrake();
[color=red][/color]
johnwasser
You are missing a '}' at the end of positionx() so any functions after that are illegally inside the positionx() function.
Code: [Select]
#define SENSORD 26
//int count = 0;
int KEY_NUM = 0;
#define SENSORA A1
int val_AD = 0;
// LED
int counter = 0;
int aState;
int aLastState;
int delaytime = 20;
  pinMode(SENSORD, INPUT); //sensor digital value
  pinMode(SENSORA, INPUT); //sensor analog value
  pinMode(outputB, INPUT); //encoder signal 1
  pinMode(outputA, INPUT);
  pinMode(7, OUTPUT); //motor positive pole
  pinMode(8, OUTPUT); //motor negative pole
  pinMode(9, OUTPUT); //motor speed
  pinMode(10, OUTPUT); //motor positive pole
  pinMode(11, OUTPUT); //motor negative pole
  pinMode(12, OUTPUT); //motor speed
  pinMode(13, OUTPUT); //led pin
  digitalWrite(34, HIGH); //signal to make motor start rotate
  attachInterrupt(26, led, HIGH); //thredhold
  sensor();
//motor attacth
void positionx()
  for ( int i = 1; i <= 5; i++ )
    motorforward1();
      int M = digitalRead(outputB);
      if (M != aState)
        counter ++;
    delay(5000);
    motorreverse1();
}  // This was missing
//motor forward
  digitalWrite(8, HIGH);
  int value1 = val + (val_AD / 8); //P control of motor1 speed
  analogWrite(9, value1);
  delay(delaytime);
  digitalWrite(10, LOW);
  digitalWrite(11, HIGH);
  int value2 = VAL + (val_AD / 8);
  analogWrite(12, value2);
  delay(delaytime);
  digitalWrite(7, HIGH);
  analogWrite(9, val);
  delay(delaytime);
  digitalWrite(10, HIGH);
  digitalWrite(11, LOW);
  analogWrite(12, VAL);
  delay(delaytime);
//motor stop
void motorBrake()
void sensor()
  if (digitalRead(SENSORD) == HIGH)
    delay(10);
      while (digitalRead(SENSORD) == HIGH);
      KEY_NUM = 1;
    if (KEY_NUM == 1)
      KEY_NUM = 0;
// LED
void led()
  digitalWrite(13, HIGH);
  motorBrake();
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
See who has no social life: https://forum.arduino.cc/index.php?action=stats :)
PaulS
Quote
As you can see, that was useless, since nothing turned red.
It would have been better to post the ACTUAL error message, with line number.
