Topic: Connection problem between L298N and DC MINI MOTOR N20-12V (Read 947 times) previous topic - next topic
RobsonOliveira56785
Hello!
I'm building a robot line follower and I'm facing the following issue: only one of the motors is working - specifically, the one on the right side. I thought that it could be the L298N motor driver, since the motor by itself is working if I connect it directly to the battery, but I already used two different motor driver and the same side wouldn't work. I don't know what else to do.
Doing some research I found that there could be a drop of voltage when I connect the motor in the L298N. However, I still find very weird that only the motor on the right side of the L298N stopped working.
Components:
- 2 Mini DC motors N20-12V
- 12V battery
- 1 L298N
slipstick
It sounds like there's perhaps a problem with the wiring or maybe the code you're using to drive things. Unfortunately I can't see either of them and your Fritzy diagram is useless because that shows you have a useless little 9V battery and most of the components aren't marked at all.
Steve
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Not a Fritzy picture, draw your diagram from your project, label pins and power supplies please?
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
