Topic: Servo is jumping on just some outputs. (Read 689 times) previous topic - next topic
ATWindsor
I have 7 simple servo motors connected to my arduino, i control them via telnet. They are running on an external 5V power supply. On some of the outputs, it works fine. (for instance 2 or 3), but if i try some others, like 7 or 8, it moves to the right place, but after that it starts "jumping back and forth" or "jittering" (not sure what the technical term is), and continues with this "forever", if i change around the motors, the result is the same, some outputs works fine, others not, apparently independent of which motor is connected. Any tips on how to troubleshoot this?
PaulS
By "output" are you referring to values, as in position, or pin numbers, as in the servo attached to pin N jitters while the servo attached to pin M does not?
wildbill
The vast majority of servo issues reported here turn out to be insufficient power. Having an external power supply is a good start, how much current can it provide? Also, what voltage is it actually providing when the servos are powered up?
ATWindsor
Sorry for the late reply, I have been withhout internet som days. I am refereing to the pin numbers. Servo attached to pin 2 and 3 doesn't jitter, attached to pin 7 or 8 jitters.
ATWindsor
It can provide 6,5A the voltage is 5,6V with the Servos powered up.
PaulS
If you have servos attached to pins 2, 3, 7, and 8, and you move the control wires around, does the jittering follow the pin? That is, if you have a servo connected to pin 2 that does not jitter, and you move it to pin 7, and move that servo to pin 2, which servo now jitters?
ATWindsor
Yes, the jitter follows the pin, not the motor.
TomGeorge
Welcome to the forum.
Can you please post your code?
What model Arduino are you using?
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom...
Everything runs on smoke, let the smoke out, it stops running....
