Topic: Problem Uploading - Arduino Uno WiFi (Read 452 times) previous topic - next topic
erictheted
I bought Arduino Starter Kit (Arduino Uno) and Arduino Uno WiFi (Barcode 7630049200234) from Core Electronics in Newcastle, NSW Australia. When I plug it in (I also bought the power supply) and ran the Blink example the Arduino IDE gave me a error message.
Here's the text file I copied to the clipboard.
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Uno WiFi"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x1c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x1c
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Windows -> Control Panel -> Device Manager tells me that the USB Serial Device on COM3 is working properly.
How can I troubleshoot this?
PS I'm going to try using the other Arduino Uno I got with the starter kit and plug in the Ethernet Shield (W5200 v1.1) and see what happens. But any help would be appreciated.
Juraj
install megaavr boards package and select Uno WiFi Rev 2
DrAzzy
Is that an Uno Wifi, or an Uno Wifi Rev. 2?
The only things those have in common is the name and the shape - Rev. 2 uses a different chip with a different architecture.
As usual for Arduino, they picked a name sure to cause confusion (just like they're releasing three "nano" boards with different architectures).
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
pert
Please don't plug anything into your Arduino board until after you have managed a successful upload to just the board alone.
