Topic: SD Card Not Initialising? (Read 730 times) previous topic - next topic
Tbdanny
Jun 25, 2019, 01:37 pm Last Edit: Jun 25, 2019, 01:41 pm by Tbdanny
Hi all,
I'm trying to get an SD card module working with an Arduino Uno, but I've run into a few issues.  I've followed this tutorial: https://randomnerdtutorials.com/guide-to-sd-card-module-with-arduino/, however whenever I run the SDCardInfo sketch, all I get is an error message listing things to try.  All of which don't apply, as I have tried (i.e. wiring is correct, card is inserted, and I'm using the CS pin defined in the sketch).
On top of this, I have also tried:
  • Plugging the SD card module directly into the Arduino pins
  • Using alligator clips and breadboard wires to connect the SD card module into the Arduino pins
  • Tried using a different MicroSD card
  • Tried using a different MicroSD card adapter
  • Powering the SD card module & Uno from a 5v supply
All of these met with the same result.  Below is the module I'm using, and how I have it wired up:
The two MicroSD cards I've tried in the adapter are 8GB and 16GB cards, which were formatted for FAT32 (Quick Format) under Windows 7.
Am I missing something, or could I have a faulty module?
mrobber
I'm having similar problems (as described in another thread), but have you tried the SD Card Formatter app instead of using Win 7?
See the pinned topic: https://forum.arduino.cc/index.php?topic=228201.0
ShermanP
I just started a new thread about a possible explanation.
https://forum.arduino.cc/index.php?topic=623299.0
But other than that, do you have a way to check that 3.3V is being delivered to the Vcc pin of the SD card (from the voltage regulator on the module)?
Tbdanny
I've got it working now.  I formatted the 8GB card with the formatter program, and tried it.  The first time I ran the CardInfo sketch, it said it couldn't find the partition.  After that, it worked correctly every single time, even after I put some files on it to test.
It also didn't help that one of the MicroSD-to-SD card adapters didn't work.
ShermanP
If your SD module works, then I'm wrong about that type of module being the problem.  Oh well.
