Topic: DHT 22 data shown with 2 Servos (Read 98 times) previous topic - next topic
Juba400m
I have a school project to do, which is using the data of the DHT 22 and display it with to Servos. I have programed the DHT 22 so that i can see its data on the serial monitor. But i cant make it to steer the Servos.
This is my programm:
#include "DHT.h" // Bibliothek für DHT22 laden
#include "Servo.h" // Bibliothek für Servos laden
#define DHTPIN 2 // Sensor wird an PIN 2 angeschlossen
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
Servo myservo;
Servo myservo2;
  Serial.begin(9600); // startet serielle Verbindung
  myservo.attach (9); // PIN 9 für Servo 1
  myservo2.attach (10); // PIN 10 für Servo 2
dht.begin(); // startet den Sensor
  delay(2000); // 2 Sekunden warten bis Sensor startet
  float h = dht.readHumidity(); // Luftfeuchtigkeit auslesen und unter h speichern
  float t = dht.readTemperature(); // Temperatur auslesen und unter t speichern
  int err;
  Serial.print("Luftfeuchtigkeit: ");
  Serial.print(h);
  Serial.println(" %");
  Serial.print("Temperatur: ");
  Serial.print(t);
  Serial.println(" Grad Celsius");
  if (t < 0) {          //Befehle für Servo eins was wenn t
    myservo.write (0);
  } else;
  if (t < 5) {
    myservo.write (10);
  } else ;
  if (t < 10) {
    myservo.write (20);
  } else;
  if (t < 15) {
    myservo.write (30);
  } else ;
  if (t < 20) {
    myservo.write (40);
  } else ;
  if (t < 25) {
    myservo.write (50);
  } else ;
  if (t < 30) {
    myservo.write (60);
  } else ;
  if (t < 35) {
    myservo.write (70);
  } else ;
  if (t < 40) {
    myservo.write (80);
  } else ;
 if (h < 50) {           // Befehle für Servo 2 was wenn h
    myservo2.write (50);
  } else;
  if (t < 55) {
    myservo2.write (55);
  } else ;
  if (t < 60) {
    myservo2.write (60);
  } else ;
  if (t < 65) {
    myservo2.write (65);
  } else ;
  if (t < 70) {
    myservo2.write (70);
  } else ;
  if (t < 75) {
    myservo2.write (75);
  } else ;
  if (t < 80) {
    myservo2.write (80);
  } else ;
  if (t < 85) {
    myservo2.write (85);
  } else ;
  if (t < 90) {
    myservo2.write (90);
  } else ;
   if (t < 95) {
    myservo2.write (95);
  } else ;
  if (t < 100) {
    myservo2.write (100);
  } else ;
Can somebody help me and say me whats wrong here??
PaulS
Code: [Select]
  if (t < 5) {
    myservo.write (10);
  } else ;
What is the point of the empty else block?
Quote
No, because you haven't told us how you are powering the servos and/or whether or not you can make them move with the Sweep example.
Servos are not driven by PWM, so you do not have to use PWM. I'd move the servos to other pins, just to see what happens.
johnwasser
Since all values below 40°C will move the temperature servo to 80 and values of 40°C or higher will not move the servo I expect the temperature servo to go to 80 and stay there.  Yes, if the temperature value is below 0°C the servo will be directed to 0 but since that value is also <40°C it will be re-directed to 80 before it can move to 0.
To get the effect you want, take out the ';' statements after the 'else' keywords.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
