Hi!
I have this chinese TFT LCD which works in 8-bit parallel very well.
But as I'm using a ESP32 (30GPIO version) my pin count is low, that's why I got a 74HC595.
So, after days searching, I really start to think if it's possible put this 3 components together.
My main difficulty is wiring all the pins on the right way. As I'm not experienced in comm protocols I'm really struggling at that task.
Since this LCD come with CS/RS/WR/RD pins, I'm not sure how to wire ESP32 pins in 74HC595 and this LCD.
ps: data pins is pretty straight forward for me.
As you guys can see I'm using TFT_eSPI from Bodmer.
Here is the code. In my last update I tried to force pins HIGH/LOW as none of the other attempts were successful.
#include <SPI.h> //https://github.com/espressif/arduino-esp32/tree/master/libraries/SPI
#include <TFT_eSPI.h> // https://github.com/Bodmer/TFT_eSPI
#define TFT_MISO 19
#define TFT_MOSI 23 // (SPI DATA)
#define TFT_SCLK 18 // (SPI CLOCK)
#define TFT_CS 5 // Chip select control pin (SPI LATCH)
#define TFT_DC 2 // Data Command control pin
//VSPI
#define T_CS 22
#define TFT_CD 4
#define TFT_W 320
#define TFT_H 240
TFT_eSPI tft = TFT_eSPI();
void setup(void) {
digitalWrite(TFT_CS,HIGH);// ||
pinMode(TFT_CD, OUTPUT);
tft.init();
tft.setRotation(1);
while (!Serial && (millis() <= 1000));
digitalWrite(TFT_CD, LOW);
digitalWrite(TFT_CS, LOW);
tft.fillScreen(ILI9341_RED);
digitalWrite(TFT_CS, HIGH);
digitalWrite(TFT_CD, HIGH);
I don't know if I'm trying to make a "miracle" by mixing 2 protocols (8-bit + SPI), so let me know if this is impossible.
Buying a HMI LCD or even a SPI LCD from China is not an option, since Nextion LCD is very expensive for my purposes, and my country have an awful delay for chinese imports.
Tell me if you need more info about docs, codes, attempts, etc.
A huge thanks!
