Topic: Enableinterrupts and NeoSWSerial incompatable (Read 2862 times) previous topic - next topic
Jorgie
Jun 30, 2019, 09:03 am Last Edit: Jun 30, 2019, 09:09 am by Jorgie
Out of the box EnableInterrups and NeoSWSerial are incompatible. This simple program results in errors when linking:
Code: [Select]
#include <EnableInterrupt.h>
#include <NeoSWSerial.h>
#define RX_PIN 3
NeoSWSerial myDevice (2,3);
void myDeviceISR()
  NeoSWSerial::rxISR( *portInputRegister( digitalPinToPort( RX_PIN ) ) );
  // if you know the exact PIN register, you could do this:
  //    NeoSWSerial::rxISR( PIND );
  myDevice.begin( 9600 );
  enableInterrupt( RX_PIN, myDeviceISR, CHANGE );
 // enableInterrupt( OTHER_PIN, otherISR, RISING );
If you compile this code the following errors will occur:
Code: [Select]
C:\Users\sean\AppData\Local\Temp\arduino_build_753120\libraries\NeoSWSerial\NeoSWSerial.cpp.o (symbol from plugin): In function `NeoSWSerial::read()':
(.text+0x0): multiple definition of `__vector_3'
C:\Users\sean\AppData\Local\Temp\arduino_build_753120\sketch\sketch_jun30a.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_4'
(.text+0x0): multiple definition of `__vector_5'
collect2.exe: error: ld returned 1 exit status
It should not be necessary to edit NeoSWSerial.h in order to make this simple program compile and link.
Please consider adding the appropriate code to enable PinChange interrupts
westfw
Who is it that you suppose would do this, given that NewSWSerial and EnableInterrupts are both 3rd-party libraries (not from Arduino itself), written by different programmers?
Jorgie
The last line of my original post is making the suggestion:
Quote
I am asking for the PinChange interrupt capability to be added. This would stop 2 3rd party libraries from having to implement their own version and thus remove the incompatibility.
